Tranny: Theoretical question
My new 96 polo has 46,000 miles on it and had the tranny fluid changed at the 30K service. I was thinking of changing over to synthetic, using one of the transmission flushing procedures.
There have been accounts of some transmissions failing soon after this changeover to synthetic. However, I have a Subaru extended warranty for 2 yrs/24,000 miles. So here is the queation: IF I change over to synthetic and the transmission DOES fail, is Subaru obligated to repair the transmission, since I am not using the factory-approved fluid? Is there a possibility that using synthetics will void my warranty? The wording is ambiguous at best. Its easy for them to say that using non-approved fluids caused the tranny to fail and that is negligence on my part. This is hypothetical and probably not worth losing sleep over (However, I never heard of engines failing soon after switching over to synthetic motor oil)
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-27-2002 at 11:35 AM. |
My question would be ... why bother switching to a synth in your tranny is already covered by a warranty?
I guess I would say why risk it... |
My .02 cents..
If you do not want the high cost of synthetics, try using ATF +3 instead of synthetics.
It is specially formulated to stand up to very high temperatures. Chrysler had a SERIOUS problem with their transmissions and developed their fluid to withstand the extreme heat. I have been using it in my SVX for maybe 5-6 years now and it is the best I've ever used. I bought the actual Chrysler brand from a Chrysler dealer because that is all that was available for a long time. I see Castrol and Aamco now sell it at Autozone for a much more reasonable price. Won't void the warranty either. |
Will Synth voild your warranty
I think it'll void it. Check your owners manual and see what it says about sythetics. I think it says they shouldn't be used at all. If it doesn't say call them and get it in writing that it will not void your warranty. If they won't let ya. I'd suggest changing your ATF when you change your oil I've just gotten used to doing it but it ensures that 1/2 the fluid is fresh every 4-6 month or 1500 miles.
Huh?
My question is 'Why are you asking us?' They're holding the bag on the warranty, call and ask them.
