Mid-window rubber seal #
Does anyone know the part number for the rubber trim gasket strip that separates the top door frame glass from the power window?
Sealing Parts
It is hard to tell in the parts microfiche that I have. In the picture it appears one piece that seals the top and the middle; however, it provides 2 part numbers. I cannot tell which part number goes to which in the picture.
There are also different part numbers for 2WD and 4WD and LSI models is different from other 4WD. But, if yours is a 92-- no problem. Parts for 92 are: LH side--90372PA010 and 90372PA011 RH side--90372PA000 and 90372PA001 It identifies them as W/S Assy Dr Sash Hope this helps Lee SVXx4 |
Re: Mid-window rubber seal #
Sorry to resurrect this ancient thread, but I am looking for the exact same part the OP was looking for. I recently had the fixed glass on my (1996 LS) driver's door broken, and after the shop replaced it I am getting terrible wind and road noise through the seal. I talked to the shop about it, and they said it was because you weren't supposed to reuse those window seals, but they had anyway to try to save me money. Neither the body shop nor my local Subaru dealer can find the part number for the seal, and I can't seem to find it either at the places I usually look (such as subaruparts.com where I bought the glass).
Can anyone tell me for sure what the part number is for this window seal? And if any auxiliary parts are needed to install it? I looked up part 90372PA011 referenced in the original thread, and from what I can tell it LOOKS about right, but that part number is for a 1992, and when I try to find the same part for a 96 I come up empty. Also, it is coming up as a couple hundred dollars, can that be right for a window seal? Anyway, thanks for any help anyone can offer. Hey, this is my first post ever! |
