Old 02-24-2009, 02:15 PM
kcbsvx's Avatar
kcbsvx kcbsvx is offline
Now down to only ONE!
Re: HID kits on the cheap.
Hi Laserx-
The AWD LLC crew mounted 5k hid low beams and clear headlite lenses on mine and I love them. Awesome light output and a nice BMW-like crisp top edge on the beam pattern. I feel the dispersion is even better than with the stock lens.
I bought, but haven't mounted yet, hi beam 5k's from DDM for the SVX and hi + low for my Outback. It looks much more difficult to install them on the OB since the bulbs are INSIDE the gasketed full plastic cover on the rear of the headlite assemblies. It looks like I will have to drill 1"+/- holes in that cover to match the round rubber plugs on the DDM wiring. Otherwise one must still drill small holes as well as cut and resplice the wiring and compromise the extremely waterproof DDM harness.
Give the other set to your son if he has an SVX, and you will both be very pleased with the result.
Christian-
96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC.
2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock
1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods
2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock
Old 02-24-2009, 02:18 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by laserx View Post
So where do I use the extra lights and ballasts?
I am a nice person... you could just give them to me??
or... Maybe call the company and see if returning them for credit is an option.
Maybe someone on the SVX form from Canada would want to buy them for their car?
Keith
Old 02-24-2009, 03:05 PM
laserx's Avatar
laserx laserx is offline
Thanks kcbsvx, I now know I have two complete sets and that I will not have any problem with my clear lens.
As for the folks at AWD, I have done business with Tom and Eric and have had nothing but the best of service and communication, they're the best.
Now for my extra set...I can use them as bribery with my son. He still has to install my new set of Koni's complete with powder coated cores from AWDa, as well as my clear lens and HID's. Then he has to tackle my MOVIT brakes...but my extra set are his.
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake.
Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB
Koni struts/ground control coilovers
Stainless steel brake lines
K&N filter, custom front grill
H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w
Clear front and corner lens
Old 02-24-2009, 03:42 PM
I ordered two HID's from DDM. They arrived today, and I didn't pay any taxes or duties and I'm in Canada...it's a hit and miss thing with customs.
Now for my question. I order two 4500k bulb type=9006 35 watt, I paid $59.95 each, with delivery to Canada total price $144.60 and expected to get two lights and two ballasts.
What I got was two boxes with two lights and ballast in each box?? I now have 4 9006 lights and 4 ballasts? Did I get what I was supposed to get or did they double the order? Can I put the extra lights in where my high beams go? Or should I just give the extra set to my son?
Laserx
It is to be assumed that you bought and paid for two kits. Each kit contains two bulbs and ballast.
Both sets will be that same, that is 9006, so they will only fit the outer projector lamps.
Your main beam is a 9005 type and your fog [or is it driving lamp in Canada?] will be an H3 bulb. So the spare set will not suit either of those positions.
Give the spare set to your son.
Old 02-24-2009, 04:46 PM
laserx's Avatar
Thanks, I just did....and he's one happy camper. These are really inexpensive kits. If I like these I'll convert the other two lights as well.
Old 02-24-2009, 05:33 PM
I am sure you will like them.
One point to note; when you buy the set for the main beams the bulbs they send you need to be the correct type. The correct type has the letter "R" in the bulb code. "R" stands for reflector. Our dip beams are projector, and they will have the letter "P".
Our main beams are reflectors, that's why you need the "R" type bulb.
Old 02-24-2009, 08:37 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
By main beams do you mean 9005? And by dip beams do you mean the 9006 bulbs?
Old 02-25-2009, 02:39 AM
Are you asking me, Iceblade?
Yes, that's correct. See post #229. We use H1 and H3 over here so the plug in sockets are different from yours.
In the owner's manual it describes your dips [outer] as 9006/HB4. The main beams are described as 9005/HB3.
Old 02-27-2009, 12:20 PM
laserx's Avatar
Well both my son and I now have the H.I.D's installed, took him about 10 minutes. I wish I'd had bought these a long time ago, what a difference. I think I'll now order the H3's fog/driving lights. Looks like you can still find a good deal out there after all.
Old 03-07-2009, 01:57 PM
Looks like this great deal is all over. I just went to the site to order a couple of sets and it is a dead link.
Old 03-07-2009, 02:25 PM
kwren's Avatar
they are still there Earl. They went up to $70.00 and have the smallest ballasts on earth? still lifetime guarantee.
http://www.ddmtuning.com/products/DD...it-101-85.html
Keith
Old 03-07-2009, 05:34 PM
redlightningsvx's Avatar
Collision Refinishing Tech
The raptor sets are cheaper and still small.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-07-2009, 05:45 PM
kwren's Avatar
what are raptor sets?
Thanks,
Keith
Old 03-07-2009, 05:49 PM
http://www.ddmtuning.com/products/Ra...it-102-85.html
Seth
Past subies:
Other toys:
Old 03-07-2009, 08:05 PM
Banned
are the 8K's more of a purple or still blue?? when do they start getting purple... I wanna get deep blue but avoid the purpleness.....
