#136
Re: Twin Turbo EG33 Build - cozykat
Marisa, any progress on your build?
We got 8" more snow. How I do miss San Antonio . Tapani |
#137
No snow here.. just been cold, windy, and rainy. Of course, as soon as my vacation is over, it is an awesome 64°... so I can admire the day while stuck in a lab. No worries, it will be cold and rainy again by Friday and through the weekend. :/ We've just been trying to get the Hydra to start with the stock engine. I had Hydra upgrade the Nemesis to 2.7 version (for included support and easier programming interface) and add a pin to control the iris valve. With the upgrade, they put a new base map on the unit so I was hoping it would be plug and play. It's been an interesting issue. I can connect the stock ECU and stock engine starts/idles/drives. Disconnect the stock ECU and then connect the Hydra Nemesis and the engine tries to start but just can't. Matt has been talking/getting guidance from Phil at Element Tuning. Phil has been a great support and wealth of knowledge. (side note: a 2.6 map will not import & update into version 2.7, the information has to be manually copied over) This no-start issue has simply left everyone scratching their head as to why it's not just working. While the nemesis fires the spark plugs differently (i.e. does batch firing), I'm not sure what else could be so different that the car won't start. We did get the car to start with version 2.6 by adjusting Kirill's map and 2.6 also does batch firing. So ... The best advice we can get is that we need to go through the normal troubleshooting of seeing what's not getting triggered/applied properly (spark, fuel, or air). So I've just been waiting for a less rainy day to systematically troubleshoot the issue (because the SVX is outside and i don't like to be cold). Once I get this issue resolved, I'll point out my installation flaws and be sure to share my base map to help others (it will just be for a stock vehicle so it shouldn't upset anyone, hopefully ).
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram Last edited by cozykat; 01-06-2015 at 04:32 PM. |
#138
I know too well how that goes. The days of vacation are always filled with nasty weather and upon return to work the sun shines...WTF! Even if it feels like no progress has been made, you really have made a lot. The situation with HYDRA 2.6 vs 2.7 tune is very interesting but not unheard of. Just a couple days ago I was talking with a buddy that uses/used COBB AP to tune a customers 2014 Nissan GTR and after the customer traded in the '14 for the '15 model the COBB AP (whole new system as they can't be unmarried, well they can but not what happened here) was no longer able to communicate with the car. They went back and forth with COBB for about 15 days and like you said "everyone is scratching their head" and it seems to be that it's NOT going to work due to the ECU for the '15 GTR being unable to communicate with the COBB AP and vice versa. I believe they were going to switch to ECUtek as they are one of/ if not the only system that supports the '15 GTR at the moment! Back to the the SVX acting like its going to start, maybe its just a temperature factor. Have you or Phil mentioned altering the temperature parameters (especially if its really cold out) to see if that will help or actually make it start. I remember seeing a video on youtube (Hydra EMS 20 degree cold start Element Tuning) way back maybe 2 years ago of him messing with some temperature setting on the Hydra 2.6 I believe. ( Actually I checked and it was the 2.7!) Hopefully you can get this sorted out as the Hydra 2.7 is what I'm planning on using in the near distant future. My buddy used to tune Hydra back when it was 2.1..... and hasn't touched it since so he was pretty surprised they were up to Version 2.7. Anyway, good luck! Hopefully this gets figured out sooner than later as you have me sitting on the edge of the chair and I dont want to fall
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker Last edited by Svx95; 01-06-2015 at 09:55 PM. Reason: Incorrect hydra version. |
#139
Here is part 2 to the cold tune start. Hope this helps even just a little! Hydra EMS 20 Degree Cold Start Part 2 Element Tuning
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
#140
Thanks Sam! It's something to keep in the back of my mind. I don't think cold starting is my issue (well, wasn't the issue during previous start-up attempts as it's just now getting into the 20s). Texas usually enjoys 40-70 degree winters. I know there was one temperature discrepancy - the air temperature is just not reading (but it didn't read in version 2.6 either and Phil said it shouldn't make a difference).
So for my next weather-permitted, availability I plan to check the wiring and look at which, if any, of the cylinders are attempting to fire with the Hydra and try to think what could be so different between the engine management systems. I think this will all require a bit more investigative work than I was hoping at this stage of the install... but I'm sure there will be some good lessons learned. Concerning upgrading from 2.6 to 2.7: I feel should also correct my statement/clarify to say that you actually can import a 2.6 map to 2.7 but not all the tables are one-to-one. So you have to effectively open both applications (on different operating systems as they didn't like being install on the same laptop - however 1 or 2 virtual machines would help with this) and compare/copy over what's different. Not terrible, just something to note. I'm just hoping there is a terrible oversight on my part and that I'll walk out, say "oh my! duh!" and success! Then I can refocus on installing the built engine and fight with that.
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
#141
Marisa
Has Phil been able to tell you EXACTLY what changed between 2.6 and 2.7? My guess is that they moved some parameters around and now the Hydra's brain is scrambled when it tries to run the EG33. Bill
#142
Hi Bill,
Maybe? Aside from look-and-feel, I don't know exactly what all has changed between software versions but we haven't really pushed for a breakdown of the software/firmware enhancements yet. Just focusing on start-up, Phil has told us the batch firing is the same between versions (and we could start the car with 2.6) so we trying to rule out potential hardware issues. On the progress side: the Nemesis adapter cabling is pinned out to correctly and the configured firing order is correct.. so I think with a bit more investigation into the rest of the start up process, we will find what isn't occurring.
#143
I forgot to post updated pictures:
grimmspeed's port and polish: and how the engine sits today (well, since September), waiting...
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram Last edited by cozykat; 01-09-2015 at 07:13 PM. |
#144
Wow, very nice! Super clean I hope some day my engine will be that clean.
Looking at the pictures reminded me that I've been looking for the o-ring or gasket that goes in the iris butterfly system? Do you have a part # by any chance? I looked over my parts catalogue but couldn't find it
#145
The best engine that I ever seen.
I wish you soon cranking. Best regards |
#146
Yes, absolutely beautiful !
What's the performance target Marisa? What's your drive train? Keep up the stunning level of detail Kind regards, /Tapani |
#147
Quick update: Got the engine to turn over and idle with the Hydra today! Last night, we went and tested each coil pack and discovered that the hydra was only firing cylinder 2. Plugged in stock ECU, verified each coil pack operated as expected. Then for good measure we installed new spark plugs and changed the oil. Today, we got feedback from Phil to update some ignition settings and I came home to the SVX idling! Next steps are to adjust the tables to get it drivable. So for the curious: Settings > Base Ignition Settings - both waste spark and direct fire need to be checked (we tried unchecking one or the other, and the result was no start.) Settings > Ignition triggers - Timing reference angle should be 65 degrees (this was already set)
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram Last edited by cozykat; 03-16-2015 at 10:44 PM. |
#148
I run Sequencer = 3 Timing Reference Angle = 68 (need to get a better timing light so i can get this exact around 65 is close) Trigger Edge = Falling Sync Edge = Falling Trigger Type = Generic 12 tooth Sync Type = Generic 12/24 tooth Cylinders = 6 |
#149
Ok will do, thanks! That is great Marisa, I'm sure there was a lot of relief once you heard it run! BTW thanks for posting the info for the curious COPY PASTE
#150
Marisa
Could yourself fortunate! Grimmspeed has gotten out of the porting business No reason given on their website. Bill
