Impreza 5 speed swap problems
My 92 Ls-L has a 98 Impreza swap but my speedometer now reads like 10MPH under what I am going and I was wondering if anyone had any ideas why.
Re: Impreza 5 speed swap problems
did you remember to swap the svx speed sensor in the 5spd?
The speedo gear in the Impreza (depending on the year and model of Impreza) is set up for as small as 13" tires, you are now turning 16" tires which are probably 10% bigger than the 13's it was set up for.....so your speedo is off....there are aftermarket fixes for this, but they do cost....
My little Daily Driver is a Impreza L FWD 5-Speed, which came with 13" wheels, and I have a set of 16" rims on it, and my Speedo is off 10%.....so 50 on the speedo is 55, 80 on the speedo is 88, and so on...you can just adjust your driving to match it, or open up the tranny and install a different speedometer gear set, or get an aftermarket electronic fix for it...
Try this page to sort out what you should be running: http://www.wheelsmaster.com/rt_specs.jsp As far as the OP's problem. It sounds like he's got the wrong speed sensor in the tranny. Since he's running the same tires before and after the tranny swap (I'm assuming) there shouldn't be a discrepency due to the 5MT.
3 turbos, 28 cylinders, 96 valves, 18 cams, 1400hp/1600ftlbs: '09 Outback XT / '06 Outback Sedan / '02 WRX / '94 SVX / '01 F-250 SuperDuty |
I believe sperry is right. Since the sensor measures the outgoing rpm of the transmission and factors in the differential ratio as well as the tire size.
As 5 speed do not have the SVX stock differential ratio to swap the SVX sensor to the 5speed would not help. So you need to match the tire size to Impreza value. Please let us know about the outcome on this. Thanks! Marcus |
The Circumference of the tires that the tranny came with will be the difference, because all trannys DO NOT turn the same output at the speed sensor location, as the Subaru Manual Trannys are still set up to drive a cable driven speedometer which they had up untill the mid 90's, and there is a gearset inside the tranny that is matched to the final drive ratio and the tire circumference Do yes, he's running the same tires before and after his swap, but the TRANNY is NOT running the same tires it was set up for, the Speed sensor just converts the rotational output of the transmission into a digital signal so no matter WHAT speed sensor you install it will not read correctly, there are aftermarket setups that adjust the digital signal between the speed sensor and the speedometer, but without that you either need to find lower profile tires to try to match the transmissions original tire size (and if it were a tranny set up for 13's you'd probably have to run just the 16" rim with a strip of rubber around it) or you would have to open up the transmission and install a different speedometer gear drive set. A bit of a plus is the SVX (as most cars) stock the speedometer is off to the slow side, saying you are going faster than you really are...so some tranny swaps actually work out to a more accurate reading, some make it worse,,,
I don't know if the person who had the SVX did the sensor switch. As for the aftermarket thing how much does that usually run?
I figured, the OP's problem was simply using the wrong speed sensor, which reports an incorrect rpm to the cluster, resulting in being off by 10 mph. If the issue were related to diff ratios and tire sizes, then the speedo wouldn't be off by 10 mph across the board, it'd be off by some percentage of the actual speed, like off by 2 mph @ 30 mph, 5 @ 60 , 10 @ 90, etc. I was under the impression that when doing a 5MT swap, if you simply re-use the SVX's speed sensor in the 5-speed, your speedo is as accurate as it ever was before the swap. Having not done a 5MT swap myself, I can't really claim to know what I'm talking about, but I'd be surprised if there were mechanical differences between every transmission related to the size of the tire that was expected to be attached to that transmission. It would be so much simpler just to draw the lines on the gauge in different spots and/or use a different speed sensor.
There's some very basic math at play here. EDIT: My mistake... The following is incorrect. The cluster is driven off of VSS2. Your cluster doesn't care what size tires you have, nor what speed sensor you have. It does what the ECU tells it. Your ECU only cares about two things: How many pulses it gets from the speed sensor in a given amount of time, and what size your tires (not wheels!) are. If your transaxle is definitely from a 1998 Impreza, and if you're using a stock SVX diameter tire, then your 10mph discrepancy can be found at no less than 333mph if the speed sensor is functioning correctly and to blame.
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 05-12-2009 at 05:26 PM. |
