#31
This car has worked perfectly up until this problem. One day I cranked her and we got about 1 mile from home and she just did not want to go. I did not want to walk so I continued to give her the gas. After about 4 miles all was ok except that I pulled over because of smoke. Many people stopped because they thought car was on fire( It was that bad). This was many months ago and it still does the same thing. It must comepletly cool down after doing it in morning before it will do again in evening. Also there have probably been 5 times out of 200 that the problem did not occur. Thanks to all for help!!
#32
The injection pulse should start high, coming down as it warms up,( don't know for sure, but it may use a double pulse,at first to supply the extra fuel ). If it is going lean you will see the pulse length shorten. I would check using a twin trace scope, comparing say the middle injector on each side, at the same time. The ECU can operate them independently, and as the ECU gives a code for one o2 sensor, it may be confined to one side. I reckon this has gone past the guessing game, and needs some expert looking into. I am sure that if this was done, it would show either the spark or fuel change to cause the trouble. If not it would have be an act of God. Harvey.
#33
I have now replaced many things including knock sensors but still have the problem. Agin here is cut and paste from subaru tech manual.
Legacy Key On ................ Red & Black/Red ............ 10-13 Volts Engine On ............. Red & Black/Red ............ 13-14 Volts Key On ............... Black & Black/Red ............ 0-0.3 Volt Engine On ............ Black & Black/Red ......... 0.8-1.2 Volts Key On .............. White & Black/Red ............. Zero Volts Engine On ........... White & Black/Red ............. Zero Volts Loyale Key Off ............... Black & Ground ............... 0-10 Ohms Key On ................. Red & Ground ............ 10 Volts Min. Key On ................. White & Black .......... (1) .1-.5 Volt SVX Key On ................... Black/Red ............... 10-13 Volts Key On ..................... White ................. 0-0.3 Volts Key On ..................... Black .................. Zero Volts Engine On ................ Black/Red ............... 13-14 Volts Engine On .................. White ............... 0.8-1.2 Volts Engine On .................. Black .................. Zero Volts notice that svx does not show where to test to. ground- etc. In earlier post it was stated to test to ground. This would be impossible because if you look at wiring diagram blk/red wire is grounded, therefore therefore 10-14 volts will never sow up on this lead. Still trying to solve this problem. Thanks again |
#34
Key on eng. off, red to body=10 to 13V, White to body 0-0.3V Engine on, red to body= 13-1, White to body 0.8-1.2V The white wire is the signal, the red the supply. If something is going on here, either the red voltage will go down below supply, or the white signal voltage will drop towards 0V, when the problem occures. All the best in your hunt. Harvey.
#35
Hi possumfat9,
What i'm about to say might be COMPLETELY unrelated. I have an older motorcycle that was doing something similar (backfiring into the intake). I had to remove the carbs and clean them out, that fixed the problem a little bit but not completely.Then i bought something called "Seafoam", it is some kind of carb/injector cleaner, I poured that in a tank of gas and it seemed to fix the bike right up. The point is, my carbs were no good, so the bike was running lean, the lean running was causing it to back fire into the intake. Do you think the injectors could be acting up when its cold and behave ok once it has warmed up. Try this thing called Seafoam, it just might help. I found the stuff at Advanced Auto Parts here in Austin Texas. I just talked to a friend of mine and he suggested: While the car is runninig lousy, start disconnected the power to the injectors one at a time (unplug, notice difference in engine performance, plug it back in, move on to next injector). IF there is one that doesn't make a difference in the way the engine is running, that could be your bad injector. Hope something out of all this helps. RB |
#36
Re: PLESE HELP! Still have problem but not what I thought!
The problems you describe may be anything, though if it's a 1994 or older I'd suspect the Crank Angle Sensor and the Cam Sensor that sit underneath the alternator. Clean these off with Seafoam or electronic cleaner such as Mass Air Flow cleaner then reinstall. May solve your problem.. |
Thread Tools | |
Display Modes | |
