Shifter adjustment
I did a trans swap auto to auto just the norm
and after it was done sometimes when you put the car what says Park on the dash and on the console shifter part it wont start. Something with the nuetral safety switch not in adjustment I didnt see any adjustment under the car, has anyone run into this before ?
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
I had Ron Mummert do that to my car when I put in the new tranny. He told me it was the ripemoff industries starter immobilizer system.
You should be able to adjust the linkage to get it right.
Generally... Japanese cars have a neutral start (inhibitor switch, to them) mounted with two bolts to the transmission, behind where the shifter cable/arm attach to the transmission. Place the tranny in neutral. It's easier to remove the arm (use channelocks if nescessary to hold the arm) and remove the nut, then the shift arm. Look at the switch, there should be a small notch in the plastic portion of the switch that will align with a slot in the portion that keys to the shifter shaft. Loosen the two attaching bolts and rotate the switch until the notch/slots align, then retighten the two screws. Reattach the arm and cable and you should be good to go.
Then again, the SVX might be totally different and none of this will apply.
once or twice before Ill give that a shot tomorrow and see how it goes.
Happened to me last week with a 91 Legacy Turbo we have sitting on the lot. I couldn't figure out why it wouldn't start; I just thought the battery was toast. It was toast, but the shifter was also not registering being in park properly, as I eventually figured out that the car would start in Neutral. I vigorously moved the shifter back and forth a few times, and that seemed to clear up the problem.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
