Old 10-18-2015, 12:00 PM
THE NEW GUY THE NEW GUY is offline
valves bend
guys, quick question: our EG33 bend valves if turned without timing belt? I changed the water pump and now the car does not start. I'm trying to start the engine before closing the timing belt cover. I checked the timing sequence and everything is OK. It tried to start the first time and stoped (not knocking). after that, no more ignition! (of course I turned the engine manually before first try with the inginition key)
Old 10-18-2015, 12:55 PM
92 SVX 92 SVX is offline
Re: valves bend
I am not sure if you asked on the facebook page but just incase you have not got an answer no the engine is non-interference.
Old 10-18-2015, 02:18 PM
Re: valves bend
never mind guys, I found the problem: I was trying to sync the timing bet with the wrong position for the crank. It's OK now. Thanks.
Old 10-18-2015, 02:20 PM
Re: valves bend
Yes I did ask in FB. I appreciate your concern, my friend. I did find the problem and fix it. thanks again.
