#121
Re: SVX poly suspension bushes
Hey my clamps arrived today - they are gold passivated - look really cool with the yellow bushes
#122
Yeah those clamps are much much stiffer than OEMs
#123
Someone mentioned that the guys from Poland would be keen to make rear diff mount bushings - if someone can measure correctly.
I cannot do that as my car is currently DD - but someone must have spare rear mount lying around ? Thanks |
#124
HERE The housing of these bushings is a sensitive case, you need someone with a micrometer scale and a set outside the car in order to get those measurements. It is a long shot.
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. Last edited by SilverSpear; 08-02-2010 at 07:28 AM. |
#125
I have a set outside of my car.. I will look to get my hands on a micrometer to get a measurement...
#126
Thanks Bobby, appreciate it
#127
The ones I purchased from Earthworm measure 2.250" in diameter. Do you need other dimensions? The center piece that the mounting bolt goes through is longer than the outside casing.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
#128
Here are the needed measurements:
#129
I have 6 new bushings purchased from Earthworm that I have not yet installed and I measured all of them with calipers and a micrometer. Measurements are in INCHES and not metric as that is the scale of my caliper/micrometer. (I will let you convert ) There is a slight variance in the dimensions of all the parts, so I will give you the upper and lower measurements. You did not ask for the length of the center bushing piece that the differential mounting bolts go through (Dark Blue diameter piece in your pic), but I have included those dimensions also. In my parts this center piece is longer than the main part of the bushing and extends further on one side than on the other.
It's obvious that my parts were assembled from stock tubing or bar stock with slight dimensional variations. Dimensions: Red 2.250-2.255 inches Dark Blue 1.130 inches Other dimensions of this subpart: 1.750 inches LONG (protrudes .170 inches on one side and .080 inches on the other side of the main bushing) Yellow .550-.560 inches Light Blue 1.500 inches Hope this helps. (Oh, for a frame of reference concerning the dimensional variations---a human hair is normally between .002-.003 inches in diameter) Lee
#130
When I installed these bushings a few months ago mine were a bit too wide. After getting no reply here, I cross posted my question on the other forum. A little birdy over there told me that he'd had to grind down Earthworm's bushings on a few occasions, and not to worry about doing that with mine. I took a little bit off the outside of both (less than a hair, an RCH to be exact) and still had to hammer them in. They fit very snug now, and I doubt that they'd come out without using the sawzall that I took to the rotten OEM ones I replaced.
This isn't a complaint about the product. They've served me well since the install, and I can't imagine my grinding would have compromised the parts at all. Just confirming that there is a little variation between those and OEM. I'd rather they are a little big and grind them down, than too small and un-usable.
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor Buying parts is like car payments. Someday she'll be all mine. |
#131
Actually I suspect a new OEM is right at 2.250 inches in Diameter. Wish I had one to measure. Lee
#132
2.250" = 57.15mm for example, is the OEM bushing really 57.15? or 57mm? Here is the question... Anyways, I will ask Chris to fab them on the 57.15mm basis, if there is any difference, shouldn't take too much trouble squeezing it in...
#133
But along the same line, I could see why some of the Earthworm parts were difficult to get in as they were oversize by at least twice that. (Some of them are slightly out of round, also) Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE Last edited by lhopp77; 08-04-2010 at 09:16 AM. |
#134
Ok Chris will get back to us with a prototype in a matter of 2~3 weeks.
Patience for now...
#135
updates on this?? anyone ever get the extra bushings? overall impressions of the whole kit??? I won't be needing trailing arm or RSB as I have the bontaeger bar and will be getting sti trailing arms etc.
