Security module Question
I have looked on the site, but haven’t found an answer. Does anyone know if security modules are interchangeable between years? I need to replace the module in my 92 and the local junk yards have a few years to pick from, although I am not sure if the security modules are still there. If they are interchangeable then I will just grab the best looking one.
Would it be better to get a later model’s module for some reason? Thanks Hal |
Re: Security module Question
What happened to the one you have now?
never worked. I get a solid red light instead of blinking when pushing the security button.
Yes, they're all interchangeable. On cars with the front passenger airbag, the module is located in the trunk. Not all models included them from the factory, but all US cars have the connector.
Later is better. And don't pay much, especially if you can't test it first or can't return it if bad. They have a great tendancy to die. There was also a TSB issued for the security system. It said that a revised module was to be released in Spring 1993, so modules from 1994 and later cars should have the newer version. It also said that the dash switch contacts had a tendancy to oxidize, so if your system isn't completely dead you might try cleaning that switch. Someday I'd like to perform an autopsy on a dead one to see if it's something fixable that's croaking.
David C. 1996 Laguna Blue Pearl SVX L AWD See my home page for SVX radio install/removal instructions and wiring harnesses |
thanks for the info. I have already pulled the module out, it was behind the glove box. Here are some pictures of the module. i took it apart to see if anything looked wrong, let me know what you think.
Hondasucks that sounds like an awesome idea, but i sure would hate to have to give up the stock SVX key FOB, I love the look of it.
I went to the junk yard today and got another security module. It cost me $35 bucks. Plugged it in, programed the remote and it works perfectly. now i just have to figure out how to get that glove box back together Let me know what happens on that TSB oregondave. It sounds like a long shot, but you never know I have a hypothesis, probably wrong, but nonetheless i have a one as to what the solid red security light means. I think it goes that way when the alarm system stops functioning, but the module will still accept signals from the FOB for locking and unlocking the doors. Although, you will be unable to program a transmitter should you have to. Thus, its just a matter of time once you have the solid light before you cant use your keyless entry. My dads SVX's security light is solid but he still has use of his transmitter, but he has never had to program it. His car, however will never arm the alarm system. My SVX light was solid but I didn't get any transmitters with the car, and was not able to enter program mode on the module, therefor not able to program any transmitter to work. anyway these are the circumstances that lead me to my hypothesis. now its time to test..... |
I called a local dealer and they told me no dice. I'll try soa tomorrow although I'm sure it'll be fruitless. Damn you're resourceful dude I don't even want to attempt getting in there. Does it look that tough sowing it back up?!
Oh and I think you're totally right. My light is solid red too and my fob was dead when I bought it, can't get my new fob to program as I can't get the f'ing thing to go programming mode.
it wont be to tough, just annoying. I am already about half way done with it, but i ran out of daylight. I should have it all finished up tomorrow...hopefully
I normally would not have attempted this so soon,it was pretty low on the priority list. Keyless entry wasnt really important and the alarm didnt seem necessary. But recently my car was stolen; It was returned, and the alarm/key less entry fix moved up on the priority list. Now, i have to say it was way worth it. I love it!! $65 for the transmitter (had to go with stock) and $35 for the module. Last edited by oblique_03; 02-06-2009 at 08:10 PM. |
I have a security system out of a newer Subaru, with the alarm siren. I also have the installation guide, it just needs a remote and the customer didn't want to buy the remote, so we removed the security system. I've been tempted to figure out a way to adapt it to work in the SVX, maybe even somehow make it plug in to the factory harness, if I could do that, then we'd have an option for security modules, since they are still available from Subaru, and the remotes are only like 25 bucks.
