95 svx dies once warmed up
Working on a 95 svx. This has me just a little baffled..It idles great untill it gets warmed up and goes to closed loop operation..Then it dies up to 5 times. Then it runs fine after that. The mass air flow sensor is new and tests fine,and all the sensors seem to test ok .Antyone have a thought on what next.Plz help!!
Re: 95 svx dies once warmed up
Thank i'll check that out ..Think im just too close to it and over looking minor problems.
The coolant temp sensor would cause that?
It used to happen to me a lot but these days its getting better |
tryed running with out temp sensors today no differance..Test look good,but it learned a new trick today now it has a irradic ideal once it is warm and will keep running about 300-400 rpm. Anyone think cleaning the throttle body might help maybe blocked air passage? I know this is a problem with toyta..
Are you getting c/e codes on the dash?
Is a vacuum line unplugged on your throttle body? Take a look to see if all hoses are connected. How long ago was your fuel filter replaced? Same with air filter...check that too. |
