Old 10-02-2007, 11:13 PM
cruisen_15's Avatar
cruisen_15 cruisen_15 is offline
problems with the a/c, well i dont know if this is related but everytime u turn the key u can look under the dash and see white pieces moving for the a/c, also everytime u give it gas the white pieces will move, making some kind of adjustment, everytime im in reverse going down a hill it hear a loud clunk and by brakes seem to give out for 1 second and my idle gets all weird and those white parts move again
Old 10-02-2007, 11:23 PM
can you post a pic of the white parts? I don't know what part you are refering to.
blk 92' LSL w/ average mods
Old 10-02-2007, 11:29 PM
cruisen_15's Avatar
i will try to get a pic of the white parts, but would an alternator cause any of my symptoms?? the wiring in it are nearly black and also i baught the svx used and it the water looking stuff from the battery got all over everything and i thought it was just water till i noticed it was acid!!! battery is good but im not to sure about the alternator either....
Old 10-02-2007, 11:40 PM
cruisen_15's Avatar
ok went and looked at my svx, heres what ive come up with without starting it up, white parts would be the vent flaps for my a/c , they keep twitching, when i turn my key to ON u here the fuel pump and then u hear a loud screatch, kinda like a cars tires locking up when braking and skidding, then if u give the pedal some gas u can hear what sounds like a bumble bee under or near the tranny....
Old 10-02-2007, 11:45 PM
Trevor's Avatar
Trevor Trevor is offline
Originally Posted by cruisen_15 View Post
well its a flicker of all lights cuzz the car nearly shuts off!! i have a hunch its the fpr, theres a vacum line that goes to it..... can i take the fpr off with no gas spilling out??
This would indicate a partial short circuit. As no fuses are blowing, the alternator is suspect. It is fused at a high rating and in simple terms. very quick high reverse voltage spikes could be involved. No one has previously reported reverse voltage of this magnitude, but it is certainly possible and could be causing all sorts of problems within the engine management system.
Refer my next post.
Trevor, New Zealand.
Old 10-02-2007, 11:48 PM
cruisen_15's Avatar
i had a new ecu intalled because the old one was shot, the shop i went to said that probly the reason the ecu went out was beacuse some one reversed the terminals!!!
Old 10-02-2007, 11:49 PM
cruisen_15's Avatar
the battery also explode at some point right before i baught the svx too....
Old 10-03-2007, 12:04 AM
Trevor's Avatar
On the basis of all you have reported and provided all has been correctly interpreted, you should replace the alternator. But sadly I must add the proviso, only if the value of the car warrants this also taking into account other foreseen expenditure. It could be time to cut your losses.
Old 10-03-2007, 12:10 AM
cruisen_15's Avatar
im sorry but i didnt under stand what u said except the part about getting a new altenator,
Old 10-03-2007, 06:30 AM
Trevor's Avatar
All here appreciate that there are those who do not post in their own first language. In this event please advise that English is a second language and we will word replies as simply as possible. Be sure that we humble ourselves towards those who have multi language skills.
Old 10-03-2007, 08:44 AM
Back IN Black's Avatar
Back IN Black Back IN Black is offline
crusin i am having the same problem. I was thinking something along the lines of a bad coil or plug. It just started doing this this am. Start cheap. I know what you mean about the lights coming on. When a car stalls, all the dummy lights come on. so rule out an electrical problem on that end. Let me guess, when going down the highway, car runs good.. you get off the exit orcome to a stop,the rpms drop real low and surge a bit.right? if so, we have the same issue. Mine did shut off once too. Start by checking your fuel filter, the check the plugs. Work that way.
92 Lsi Pearly White.
All stock. . .and that's fine by me.
2000 Mustang GT
NOT stock 450 rwhp
Old 10-03-2007, 12:33 PM
cruisen_15's Avatar
well i can not really relate to your high way problem but i can say if im doing like 55 than just get to 65 it will completly hesitate so bad it feels like im going over pot holes, ive already replaced my fuel filter, my fuel pump makes a loud skreatch when u turn it on, kinda like a cars tires locking up when they brake, how do i clean my FPR, i need to take it off, is it under pressure? could a bad one be giving me troubles???
Old 10-03-2007, 01:59 PM
I just got word from the garage. Mass air flow metor . $400 from subaru. I hope your problem is cheaper but I think thats what you have
2000 Mustang GT
NOT stock 450 rwhp
Old 10-03-2007, 02:39 PM
cruisen_15's Avatar
i dont think its the mass airflow sensor, i tried a good one off a 98 legecy 2.5, i didnt see any diffrence....
Old 10-03-2007, 06:25 PM
cruisen_15's Avatar
bad fuel pump
ok so for any of whom have been following my post about my troubles and symptoms, i have concluded that it is my fuel pump because all my symptoms dissapear when i am on empty!! wow, amazing huh!!
