Another "Window Sleeve Lock Regulator" Thread...
So it seems as though I might have the dreaded broken window sleeve lock regulator issue. However, I've looked through all the threads on the issue, but none seem to be quite like mine.
The driver's side window will roll down just fine, but it will not roll up. I popped off the panel, and there isn't much slack in the cable. Also, it's nearly impossible to move the window up (from the bottom of the door), to check and see if that simple plastic piece had indeed broken. It seemed, from the other threads, that whenever the window sleeve lock regulator had broken, the window was easy to move up and down within the door. Does that mean I'm looking at another issue all together? Any help would be greatly appreciated!
1996 Laguna Blue Pearl SVX L - 70k |
