Rims...Offset
Has anyone ever seen rims for our cars that have a offset close to the 55 that is stock....
I see a lot of 40 and 42.. has anyone had issues using 40 or 42? Thanks |
There are rims with offsets that are >= 50 mm, but they are generally very expensive ($250+ per wheel). If you're willing to settle for a 48 mm offset, Rota has a number of wheels that are $150 or less that fit the SVX.
Rims
mbtoloczko,
Thanks, I lived in Seattle until 4 months. I will be back there after school. Love it out there. I will look at the wheels. Does anyone have PICS with these rims on there cars? Thanks Again, This is one great site.... |
Check with Dayle, SVX-Motorsport, he has several wheels that fit and work well on the SVX for around $400-425 a set. many of the SVX wheels are already shown on his site.
Chris G 92 Pearlie, sold @ ~209k miles. Now owned by Tim. Current Ride, 1985 Honda Aero 80, stock 3024 klms |
Re: Rims
Here are the Rota wheels that I've been able to find that fit the SVX: Fitment: 17x7.5", 48 mm offset, 5x114.3 bolt pattern, lugcentric (not an issue) * Subzero, 17.5 lbs * Downshift, 18.5 lbs * Attack, about 17.5 lbs * Tarmac (45 mm offset), 16.5 lbs * Action, 17 lbs Rota has also just released a new wheel calle the "Torque" which is a 17x8" wheel and comes in a 48 mm offset. I expect that it will be available soon in the 5x114.3 mm bolt pattern. You'll have to look around on the net to find pics. Search with "Rota" and then the wheel names.
