SVXBot
Old 11-07-2017, 09:34 PM
simboglide's Avatar
simboglide simboglide is offline
No start, just lights
Past few weeks, I've had to " jiggle" the key a bit to get the ignition to turn. Now , with the key out, the steering wheel won't lock .Tried the key in park and neutral, lights light up, no cranking no clicking.Ideas?
Old 11-08-2017, 03:39 PM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
These exact symptoms happened to my SVX a few months ago. Got to the point where if I sat there and I was LUCKY it would crank one in about 50 turns. I replaced the starter(?) relay under the dash and that helped for all of a week.
Try this mod:
http://www.subaru-svx.net/forum/showthread.php?t=62672
Post #2 has all the info you should need.
1992 SVX LS-L Pearl White: '99LGT 5MT, Custom Short Throw, LD Performance AFR
Sleeping for the winter.
1995 Impreza L Green: AWD/5MT/2DR. LGT wheels
Daily Driver, Amassing EZ30 swap parts...
Old 11-12-2017, 11:37 AM
simboglide's Avatar
Re: No start, just lights
Really don't want to " mod" anything,,,I'm assuming the factory relay has lasted over 200,000 and i'm O.K. with that, problem is,,, everyone is showing a Bosch 5 prong relay( which i have a drawer full of, along with a matching receptacle) But from what I can see,, everything is pointing to this...25229AA050 , as being the starter relay. Easily seen under the dash....so I'm confused as to what I'm actually looking for/ at.
Old 11-13-2017, 09:09 PM
simboglide's Avatar
Went ahead and tried the relay mod,, didn't work, although the car did start 5 times in a row after replacing all the stock wiring,,shifted it and out of gear while running... back to park and then killed engine...now, same symptoms as before... all lights,,,no start and still my steering wheel still wont lock with the key removed.
Old 11-14-2017, 10:02 AM
Tireiron Tireiron is offline
Try starting it with the shifter in neutral. If it starts every time in neutral, chances are the shift selector switch on the side of the transmission is worn out and not making good contact in park.
Old 11-14-2017, 04:02 PM
simboglide's Avatar
No starting in neutral or park AND even with the key out, you can still turn steering wheel.
Old 11-17-2017, 06:37 AM
simboglide's Avatar
Doing the relay mod, the relay just clicks away.
Old 11-24-2017, 10:01 PM
oab_au oab_au is offline
All the things that you say in your first post, points to the key switch falling to pieces.
The back of the switch with all the contacts, is held to the tumbler by three tangs that are bent over the back, they end up letting the contact block move away from the switch wiper,,, no contact.
Pull the covers off and have a look, if you need another one, you can change the key tumblers over.
One Arm Bloke.
Tell it like it is!
Old 11-25-2017, 08:40 AM
simboglide's Avatar
Guess it'll be a good time to clean up the console area since it's laying in the garage floor.Seat may as well come out to make the column covers easier to get to and clean that area too.Thanks for the reply! was about to start in on neutral safety switch.
Old 11-26-2017, 11:12 AM
simboglide's Avatar
O.k. got the switch exposed,, tested the wiring at the switch and all seems to be working fine.The Black and yellow wire " fires" when key is pressed into " start" position. Where does the B&Y wire go? I can't find a diagram.
Old 11-27-2017, 12:20 AM
From the ign. switch, down to the gearbox, P,N, inhibitor switch, then to the starter solenoid.
One Arm Bloke.
Tell it like it is!
Old 11-27-2017, 06:59 AM
simboglide's Avatar
Seems I am getting fire to the starter, I'll test tonight for voltage ( I assume it needs 12v) .
Old 11-27-2017, 03:45 PM
Yes 12V and about 25 amps.
One Arm Bloke.
Tell it like it is!
Old 11-27-2017, 09:57 PM
simboglide's Avatar
12.2 V To the spade connector that slides on the blade on the solenoid. Didn't check amps though. I assumed bad starter.. 2 different Autozones say differently as the Bendix engaged at both stores.... grrrrr
Old 11-28-2017, 08:28 PM
simboglide's Avatar
Still never found the elusive under dash relay.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
2001-2015 SVX World Network
