sti wheels on an svx
I recall only certain year sti wheels will fit our cars..? I wouldn't mind having some goldies on my silver, I think it would look pretty good. I have a 92 if that matters.
Brian |
Hi,
Version 9 Impreza wheels 05 onwards have the same PCD, not sure about hub size & offset. Darren |
05-07 STi Wheels will work. They fit perfectly, my track wheels are STi BBSs wrapped in Toyo RA1s.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
Okay thanks. I dug around and found the 04's had a 5x100 bolt pattern, 05's and up were 114.
Brian |
No problem. THe only thing I noticed, they're a little heavier than my Fliks. But they're stronger because of the forging. Either way, they fit 10x better than any aftermarket wheel, no hub sentric rings needed. What kind of tires do you plan on running?
not sure, some summer-only ones.. maybe S03's or azeni's. I come home in August so I've got time to dig around.
Brian |
