Bad Shift Points
Automatic Transmission Before rebuild:
1st: 45mph/6500rpm 2nd: 80mph 3rd: 130mph After rebuild: 1st: 40mph/6150rpm 2nd: 75mph ... This sucks! Gained much time on 0-60. Took it back and tranny place said nothing they did would affect my shift points. I tried removing resistor but that didn't help. Does anyone know how this happened or how I can fix it?
Early deceased SVXWN Member July 1986 -- February 2007 Michael - Duct Tape Man 1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit 1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something. "It's only after we've lost everything that we're free to do anything" - Fight Club "This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X |
um... this may sound simple, but sometimes the simplest things are overlooked... are you in power mode??
svx: the most effective diet (distant memory) mr2: diet on the diet (on the chopping blocks) urs4: looks stale, but good performance... hoping this one will last.... but too bad it didn't mrspyder: gotta have a drop top in cali... always looking for a reliable 5spd svx... |
If you find out how to change the shift points, be sure to tell us!
I know most of us wouldnt mind shifting at 7k
[/COLOR][/COLOR]-Scott My Locker 2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14 2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14 1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65 1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07 1994 Pearl White LSi Bought: 2001? Sold: 2004? |
Yes, I am in power mode. I even put it in first gear manu. mode to make it shift a little higher but it's not nearly as good as it used to be.
Yoda, what year is your SVX? Did you have a Subaru remanufactured tranny put in your car, or did the shop rebuild your old one?
My car is a '92 LSL. I had the original automatic rebuilt at a non-subaru transmission shop. Budget Transmission Masters.
You should be able to engage power mode in any gear simply by releasing the gas pedal then flooring it.
Some people also floor it twice but I find that unnecessary.
The day I got my car out of the shop the alternator died and I got that replaced at our local dealership. You don't think that could have affected the shift points do you?
What're you guys's shift points for comparison. I did a 0-60 today at 9.3.
This may not be helpful since I know nothing about the Subaru tranny yet, but I had an 86 Jag 6 cylinder with automatic transmission, and the shift points were adjustable. Not through any obvious means, but through a cable adjustment that the book said was to compensate for band wear. Playing with that would make the trans shift either WAY early, or not at all. Setting it just right got it to shift just before redline.
Maybe the Subie has something similar? Craig |
That acually helps a lot and makes a lot of sense. When I got my car back the shift indicator was off from the P,R,N,D,3,2,1 windows by the shifter by like a quarter centimeter. When I took it back they said they didn't do it and they couldn't fix it. (Lying B*st*rds!) Do you think the cable to the shift lever could be related? I'v been meaning to tear it apart and see if i can adjust it.
Thanks a lot Craig.
