Cranks -- No fuel, no spark?
Hello,
I pulled away from a stop sign at a normal rate, and the car died halfway through the intersection. No warning, just OFF, as if the timing belt went. I checked the belt, perfect. Checked the cam and crank sensors... fine. I have found, that I have no spark and no fuel pressure. I went through the fuses under the hood, everything checks out. I haven't checked any fuses under the dash. Just came inside after 8 hours of working on it... 11 pm in the driveway with a flashlight I have a spare ecu I will try. If not the ecu... maybe ignition switch in the column? I am out of ideas. Any thoughts would be greatly appreciated. Thanks --- Jon |
Re: Cranks -- No fuel, no spark?
And with the key on, nothing comes out of your fuel line from the tank? Also when you turn the key to on, does the fuel pump buzz at all, and do the power windows and sunroof work? |
Nothing comes out of the fuel line when I turn the key on. I do not hear the fuel pump buzz. The windows and sunroof work. |
Let us know exactly which electrical items do not function as they should, when the ignition is switched off and importantly, on. There are many possibilities, including a faulty main relay.
When I turn the ignition on, only one of the relays under the hood (in the fuse box) is clicking. Should they all be switching or is that normal. Where is the main relay located? Does anyone know where I could find a wiring diagram? Electrical problems are not my expertise... if I even have an expertise |
http://www.seccs.org/tech/manuals/1992_SVX/index.html If your windows and sunroof work with key on, you can eliminate the ignition switch. Now since the fuel pump does not come on, you can check or switch out the relay. The fuel pump also has a modulator in the trunk... make sure nothing is sliding around in there that could have hit it. Lastly if everything else checks out good, and you have a good 12 volts to the fuel pump with the key on, then replace the fuel pump. |
I don't believe it to be the pump, only because I lost spark as well as the fuel. I will keep checking here, in between trying different things. Thanks everyone for the help. |
Did you check for codes, just in case one was set when you stalled? |
