Drivers side rear window not working
My driverside rear window doesnt work today.
Just stopped working. Hitting switch on drivers door does nothing, same with from rear seat. I get no noise at all, like its not plugged in. Where is the relay switch thing for the driverside rear window? Anyone got a part number? Any other suggestions for what may cause this? |
Re: Drivers side rear window not working
Hey! Mines done the same thing since I first got it. Doesn't react to any of the switches and you can't even hear any motor or movement right?
We're broken rear drivers side window buddies!
correct, no sound at all. not even trying to move. worked fine yesterday. I am assuming its not fuse related seeing the rest of the windows work fine.
I just need to know where to start looking to fix the problem. i dont care if i have to replace the entire rear power window actuator, I just want it fixed. Well if someone suggests a fix ill go for it and try it and let you know, then we can be happy working rear window buddies. |
Sometimes they get stuck if they haven't been used for a while. Try and move it with your hand or a suction cup while pressing the button.
Easy way to go:
Check for 12 volts at the connector on the motor when either window switch is pressed. 12 volt signal present means the motor is stuck or dead, no 12 volts means you need to check your connections between the main switch and the motor. |
window was fine yesterday, i have been rolling them up and down without issue for the last 3 weeks. So i don't think its stuck.
Ok I would love to test the line into the rear window motor. Where is it and how do I get to it? |
