VISOR repair/replacement
My visor has evidently lost its magnetic strength to keep the mirror cover flap closed (over the light switch). I use the visors somewhat as a sun blocker (almost always forward against windshield), since window tint is illegal on windshield and front side windows in my area.
Is there any good way to repair ...or should I look up replacement cost from Subaruparts.com? THANKS for your help!
Does it droop? If not, maybe try velcro. If it does droop, I think I would replace it.
Try the how to Documents I'm almost sure theres an article or two.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I took my drooping visors apart, they don't look broken like in the pictures . What am I doing wrong? They look like solid foam
theres a plastic(maybe metal?) only far enough to connect the hinge bar to this area is worn most likely. even a couple of thousanths can cause is to go down. Thats why they used zip ties to Squeeze it all back toghether.
Falling Visor Problem.
I have replaced my driver side visor with used svx visors.
this works for a while, but replacement visors eventually fall. so i pulled out the trim around the drivers side window just enough to allow the visor to rest on it. it isn't pretty but it works well enough that i don't have to duck to see under the visor
DWAYN |
Visor flap falling
SO....I guess the visor magnetic closure can't be fixed.....Then,where do you buy the VISOR from at a decent cost...So far, I can't get a part # or cost from Subaruparts.com...?
THANKS
Here is the 1993 SVX interior accessories page from subaruparts.com. Since all the beige visors (and other beige parts) are the same from 93 to 97, use the 1993 SVX page as a starting point when searching for beige interior parts. The 94-97 pages do not have a "sealing and trim" section to search for interior accessories.
http://www.subaruparts.com/diag/?mod...category=931-A I din't know why there are price differences between the US and Canadian visors
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 06-06-2005 at 05:48 AM. |
THANKS! I don't know why I couldn't find the interior link? $110 ....YIKES! HUH?
go to ebay i live in australia and buy my parts on ebay from US from a guy bmibay@bmicad.com very approachable and has a stock of sunvisors, radiators etc etc for SVX
falling visors
i really think subaru should have recalled these non lasting visors.
another posibility would be to find a pair of decent visors ones that last like they should and fit the decor of the car then tap and thread new holes to fit the mounting holes of the new visor. one might have to cut a piece of metal or wood to fit the new visor mounting hardware then drill holes to fit the holes in the car then drill and thread holes in the medal adapter to mount the chosen new longer lasting visors. seems like a round about way to do it, but at least one would have visors that wouldn't soon be falling. i don't know if i would actually try this, maybe on my parts car someday if i get around to it.
DWAYN |
