Revs while shifting
Got my transmission rebuilt in December, no problems with it at all Execpt:
Someones while switching gears, it revs up a little while its inbetween gears (`500rpm). Should i take the car back to the tranny guys(1yearwarrenty)? Or is the problem electrical related? It rarly happens.. About once every 3 drives... thanks,
-Khalil *1992 SVX Red. Now 100k and climbing Tranny rebuilt @ 84k. Repaint @ 87k. Mods (in order of install)- K&N air filter, ECUtune stage 1v.4, Alternator mod, removed intake resonator, B&M Supercooler, Window Tint, JDM Emblem, Hid Kit 5000K. |
when it happens, is it all the shift points, or just some (& which ones)?
Couldn't really say, happens durring slower speeds so probably between 2nd and 3rd..
Possibly between 1-2..naw probably not... im pretty sure its 2nd - 3rd gear.
Possible issues:
- TPS out of adjustment - band brake out of adjustment - worn clutch was not replaced
-Bill
ditto, ditto.
I would place least emphasis on the clutch - not as an expert opinion - just for some reason I think the weak clutch in the Subaru is the high clutch, which means you would first see slip in 3rd to 4th gear changes (or so I believe, but then again I believe in Santa Claus too). The TPS check is easy and only requires a VOM and a safety pin. The band adjustment requires only a 17 and 7mm wrench (but small hands, coupled with a contortionist background couldn't hurt. ) |
What exactly does the TPS do?
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
The TCU takes the data and sets things like the POWER mode, and changes the shift map, adjusts pressure levels, etc. |
