Tick, Tick, Tick - Thicker Oil or Motor Flush?
I have what sounds like a stuck lifter in the front passenger side of the engine.
A couple of nights ago I started my car and the sound was gone! After a couple of minutes it was back. The air temperature was 31 degrees when I started the car so the oil was nice and thick, as the engine warmed up the oil thinned down. I'm currently running 10/40 oil, what is the thickest oil I should try to run to keep that darn lifter pumped up? I know I'll lose some mpg, but that'll hurt less than an engine tear down to replace the lifter. Should I use some sort of engine cleaner to hopefully flush out whatever is in the lifter? Thanks in Advance,
Dan Pentiums - Melt in your PC, not in your hand! Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete. His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing. Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing. Mods: PWR Radiator! Problems: Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too! Ticking from front of engine, passenger side - Stuck lifter? |
Try an engine cleaner - worked for me in both svx's. Follow the instructions exactly as they are written.
I used "WYNN'S" on my old 1985 Mercedes 200 like 6 years ago, when i used to open the oil cap, i can see the camshaft completely black from sludge... I went against the instructions of using it (which states that i should keep the additive for a maximum of 70 miles before emtying the oil. Well at first i did that, but the sludge never went away and my Tick Tick thing persisted. I put another bottle another time, and kept it for 2500 miles ( ). after that my engine became as shiny as a silver dollar. Fuel consumption also decreased.
Just to keep you confused, I switched to 5W30. No more ticking.
Jerry 2005 Baja Turbo 2008 Ford Crown Victoria Police Interceptor jnj7707@yahoo.com |
Careful of cleaners...they may decay your seals
I have found that if a car sits for awhile, they will tick at first and then after they have been driven for a while, they stop. I have used some Marvel Mystery Oil in mine before and that will stop the ticking. I use 10-30 in all of mine.
