poor fuel economy
my 92 svx lsl awd is getting horrible fuel mileage. i get about 125 miles per tank where do i start and what do i do. it's got 99,000 miles and the previous owner had the o2 sensors changed at 80,000. i just had the plugs changed about 4,000 miles ago. also sometimes it will randomly stall at low engine speeds like when i come up to a stop sign, this has only happened about 4-5 times. and one more thing some times in the morning when i start it it will have a little bit of blue smoke from the exhaust. thanks in advance Curtis
Check all hoses
It sounds to me that at least a place to start is checking all the vacuum hoses. you might also want to check the MAF sensor and the air filter. then try to figure out if the fuel pump is dead or the fuel filter is stuffed.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit. Next changes ... PAINT, fix engine problems, 4.44. (GONE) '97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE) |
I suggest that you look under the snorkle were it clamps to the throttle body as they generally fold over then suck air in. This will cause the blue smoke. Use a mirror to look underneath.
Tony
I Checked The Fuel Pump And Its Got The Right Pressure And Volume So Thats Not It
put in a new fuel filter and cleaned the maf sensor and the milage went from 14 to 19mpg highway. it used to get between 22-24. anymore ideas? also checked the wheel bearings and they seam to me good
