Re: NEW Fuel Pump.. . Brand?
Did you replace the inside-tank filter "screen"?
BTW.. . My other thread about this [my pump stopped and then started after I removed and re-inserted the harness connector on top of the gas tank?] has not even got a comment! Doesn't someone know about my prospects for this old (202K miles) fuel pump continuing to work for some reasonable period?? HeLp!? Thanks, Jim
I've no idea what OEM-equivalent availability might be at an auto parts chain, but if a proper replacement is available I can't fathom why you'd want to buy something that necessitates modifications, unless it's to save big money (which I doubt). dcb EDIT: AutoZone's Web site lists an "Airtex Master" fuel pump with a one-year warranty for $85.99; in stock at the store nearest me or available for home delivery. It's the only pump they show for an SVX. Certainly could be it's a "one size fits all" unit that requires fiddling to make fit. I'd ask. Last edited by dcarrb; 04-20-2010 at 05:01 AM. |
Concerning your other thread, it's tough to say. I had fueling issues about 6months ago that I "fixed" with a new battery. I now suspect that the first encounter with this issue was an early sign of the pump's impending death.
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
I have no idea how the tank cap comes off (screws off?), let alone how the fuel meters and fuel pump are attached inside the tank??? [I don't need to remove the gas, do I?] I assume the cap screws off.. . and can be removed with a rigged jig to engage the cap ring flanges (?). I hope I can reuse the cap sealer "gasket" (Can I?). I'm concerned about the noise this unit might put out after hearing so much about noisey aftermarket fuel pumps. However, I agree with your assessment that this "incident" might be the very near "beginning of the end" for my 202K miles pump! Please send even a sketchy "How To" ASAP as I must make my decision very soon. Thanks for your help.. . Jim
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 04-20-2010 at 11:12 PM. |
the how to is done, though it would be infinitely better with pics. How do I upload it?
Mat: I hope someone else can help you . . ? I'm not the IT guy.. . Sorry! Can't wait to read tho.. . Jim
For now, just PM your e-mail address to me. We can get it posted here later.
Mat: Thanks for the extensive "HOW-TO"!
(1) Can I just use the enclosed crimp wire connectors to attach the new pump wires (mine has a nice 2-wire harness) to the upper OE wires? Is it safe electrically.. . Or should each of us place a fire extinguisher in our laps if we go anywhere?? Can I use typical shrink-wrap to tidy up the connection, or is it safe in the gas?? (2) Can I do this with a lot of gas in the tank? I just filled up. (3) How far down is the 8mm bolt.. and L-shaped bracket? (4) Can I do under gas? (5) How far out can you pull the tank cap up while still attached to the internal pump harness AND fuel line(s)? How much slack before you have to remove harness and fuel line(s)? Is there one.. or 2 fuel lines under (attached to) the tank cap? (6) I wish I could use a new seal, but seems like it will take ~10 days?? Thanks, Jim
