Old 04-02-2003, 07:56 AM
CARLiTO_
Unhappy Check engine light came on..
Today i was driving, and my check engine light was on for a minute, anyone have any ideas? Could it be the battery as i think my battery is close to dead beacuse my deck does not seem to be working and yesterday my car did not start the first few tries, sounded like the battery was dead.
Any help would be appreciated...
Old 04-02-2003, 07:59 AM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
To retrieve codes (they're also in the How-To Locker):
1) Remove the kick panel just beside the left foot rest on the driver's side.
2) Locate blue wires.
3) Locate black connector. Hold it notch up.
4) With ignition off, insert one of the wires into top row, 2nd pin from left.
5) Turn key to on position, but do not start the car.
6) Watch blinky check engine light on dashboard. Count blinks. Long blinks = 10, Short blinks = 1.
7) Keep watching blinky light until you get mesmorized.
You may want to clear codes to make sure that old codes are removed from system before determining problem. I would personally read codes now, clear the codes, then wait until the CE light comes on again to retrieve the codes.
To clear codes:
1) With engine off, stick the blue wires to 1st and 2nd pin in the top row counting from left on the black connector, with notch facing up.
2) Start car. Shut off car. Remove pins.
3) Read codes to make sure they are clear. No codes = steady blinks at 1/4 second intervals.
-- 1988 and Later Models with Multi-Point Fuel Injection --
CODE PROBABLE CAUSE
11 Crank Angle Sensor or Circuit
12 Starter Switch or Circuit
13 Cam Position Sensor or Circuit (TDC Sensor on Justy)
14 Fuel Injector No. 1 (Legacy, Impreza, Justy, SVX)
14 Fuel Injector No. 1 and 2 (XT, Loyale, GL, DL)
15 Fuel Injector No. 2 (Legacy, Impreza, Justy, SVX)
15 Fuel Injector No. 3 and 4 (Loyale, GL, DL)
15 Fuel Injector No. 5 and 6 (XT-6)
16 Fuel Injector No. 3 (Legacy, Impreza, Justy, SVX)
16 Fuel Injector No. 3 and 4 (XT)
17 Fuel Injector No. 4 (Legacy, Impreza, SVX)
17 Fuel injector No. 1 and 2 (XT-6)
18 Fuel Injector No. 5 (SVX)
19 Fuel Injector No. 6 (SVX)
21 Coolant Temperature Sensor or Circuit
22 Knock Sensor or Circuit (Right Side on SVX)
23 Air Flow Meter or Circuit (Exc. Justy)
23 Pressure Sensor (Justy)
24 Air Control Valve or Circuit (Exc. Justy)
24 Idle Speed Control Solenoid Valve (Justy)
25 Fuel injector No. 3 and 4 (XT-6)
26 Air Temperature Sensor (Justy)
28 Knock Sensor No. 2 (SVX, Left Side)
29 Crank Angle Sensor (SVX, No. 2)
31 Throttle Position Sensor or Circuit
32 Oxygen Sensor or Circuit (No. 1, Right Side, On SVX)
33 Vehicle Speed Sensor (VSS) or Circuit
34 EGR Solenoid or Circuit
35 Purge Control Solenoid or Circuit
36 Air Suction Solenoid Valve (Impreza)
36 Ignitor Circuit (Justy)
37 Oxygen Sensor (No. 2, Left Side, On SVX)
38 Engine Torque Control (SVX)
41 Air/Fuel Adaptive Control
42 Idle Switch or Circuit
43 Throttle Switch (Justy)
44 Wastegate Duty Solenoid (Turbo Models)
45 Pressure Sensor Duty Solenoid (Turbo Models)
45 Atmospheric Pressure Sensor or Circuit (Non- Turbo Models)
49 Airflow Sensor
51 Neutral Switch (Manual Transmission Models)
51 Inhibitor Switch (Automatic Transmission Models)
52 Parking Brake Switch (Exc. Justy)
52 Clutch Switch (Justy)
55 EGR Temperature Sensor or Circuit
56 EGR System
61 Parking Brake Switch (Loyale)
61 Fuel Tank Pressure Control Solenoid (Impreza)
62 Fuel Temperature Sensor (Impreza)
62 Electric Load Signal (Justy)
63 Fuel Tank Pressure Sensor (Impreza)
63 Blower Fan Switch (Justy)
65 Vacuum Pressure Sensor
Old 04-02-2003, 08:00 AM
vkykam's Avatar
Carlito,
Or you could track me down and I can do it for you.
VK
Old 04-02-2003, 11:42 AM
CARLiTO_
i followed those steps, connected the blue wire in the 2nd pin..
it doesnt blink tho..
all the lights just stay on...(STEERING, CHECK ENGINE....)
am i doing somehting wrong or does it mean that it's ok?
Old 04-02-2003, 04:31 PM
vkykam's Avatar
It'll blink, regardless. Either an even blink (OK) or long and short blinks (code).
Make sure you insert wire with key in OFF position, then turn the key to ON (not start the car).
VK
Old 04-02-2003, 05:49 PM
petesvx2's Avatar
petesvx2 petesvx2 is offline
It could just be a bad connection from the terminals to the battery. Mine was doing the same thing and the light would come on randomly and go off whenever it felt like. Check your connections out.
1992 Pearlie ... ??????k Sold 8/04
Kenwood KDC-MPV619
Wedgie Cupholder
1998 Acura Integra LS 74k Sold 1/07
2007 Toyota Tacoma Prerunner SR5 .04k!
2011 Toyota Tacoma Double Cab, 4x4 TRD Sport
Old 04-03-2003, 02:41 PM
Make sure you're using the smaller black connector. You may need to dig it out a bit.
