Old 03-16-2003, 08:29 PM
billisa
Question No air through dash vents?
I remember reading something about this, but can't find it. Just last week I stopped being able to get air through the dash vents. It will only come through the floor vents or defrost. Isn't there some actuator I can grease?
Old 03-17-2003, 10:33 AM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Check to make sure the doors in the ducts under the dash are opening freely; they can be lubed if they aren't. That may not actually be the problem - the climate control brain decides when to open and close things, and doesn't always use human logic to do so (at least not my human logic).
Also do a climate control diagnostic test to see if it shows any faults. Should be a how-to for the diagnostic somewhere on this forum.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 03-17-2003, 01:24 PM
Paxton71
no air from center vents
There is a single servo that controls both the location and the heat flapper. This Sevro can fail. It isn't hard to get to, it is under the dash, passenger side, center console.
Undo the control rods, and pull it down for testing. You can start the self test mode on the climate control by holding... Hmmm I can't remember, 2 left top buttons and turning on the ignition. It will return error codes as to what is wrong, it'll be this flapper motor. You'll hear the motor on the servo run (or try to run) during the self test.
I know this isn't EXACTLY what you want, but a search on climate control self test will help get you started.
Old 03-18-2003, 05:23 AM
CigarJohnny's Avatar
Not that you haven't already checked but what I have found with mine is that when in "auto" control, warm air (when needed) blows though the defroster and floor vents and cool air (when needed) blows out the dash vents. Do you get any air when you sent it to "Vent"? This should pipe it directly through the dash vents. If not then you should begin looking for control problems like above.
Old 03-18-2003, 02:24 PM
billisa
Lube problem, I think.
I can make it work by pushing a plastic armature, (under the dash near the driver's right foot) so I think a little grease applied somewhere might help. I just have to see more closely where to apply it. Any clear suggestions would be most appreciated.
Old 03-18-2003, 11:59 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
i dont know about you guy but i dont think ive ever gotten hot air in through the vents, after 78 ish (dont rmember) it will cut off and send it all to the floor...unless its on defrost
phil
~Phil
Old 03-19-2003, 05:19 AM
one of my major gripes about the SVX - the climate controls. this is one area where less would have been more. the cold AC is superb, though.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 03-19-2003, 10:09 AM
I think the climate control does a good job. Every once in a while I may change it a degree but it does everything I want it to.
I find that once the interior is at the selected temperature it does overcompensate a bit to keep it there. (cool air from vents to warm air at feet repeatedly)
Old 03-19-2003, 10:24 AM
i'd like to able to put the heat/cold WHERE I WANT IT, not where the computer decides it should go! three fan speeds is kinda weak, too - sometimes i'd like an "in-between" setting.
Old 03-19-2003, 11:05 AM
Ok, maybe a medium-high fan setting would be nice. There is a big difference between medium fan speed and high fan speed. In auto though the fan speed seems infinitely variable.
Old 04-14-2003, 09:21 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
The control unit is EASY to disassemble. White lithium grease all of the moving parts. Mine had jumped a cog and I was able to reseat it. Be sure to note (or take a digital pic) of the armature (white plastic control rod holder) position, or you will be spending hours trying to get it positioned correctly!
Dave W.
______________________________
1996 Redd
Old 05-26-2003, 04:16 PM
Loki
Could someone please take a pic or something of where this is? I am unable to see the armature, do I need to dissasamble the dash or console? Thanks for your response, BTW my 134a leaks out in 4-5 day's, Is that a big or small leak? Is that leak sealer or the $15 MaxiSeal stuff at all helpful or is it just for the poor sap who thinks it would actually help. Thanks again.
Old 05-26-2003, 06:47 PM
marlettpat marlettpat is offline
THE MEMBER
Send a message via AIM to marlettpat Send a message via Yahoo to marlettpat
just a stupid question, but i have wondered this before, but then i turn off the defroster and it works. DUH to me!! just a thought
