Old 08-15-2002, 09:28 PM
vkykam's Avatar
vkykam vkykam is offline
The Road Less Traveled
Unhappy Snap, Crackle, Pop.
No, I'm not talking about Rice Crispies here.
That's pretty much what I heard after closing the drivers side window this evening. Window no longer opens, although you can hear the window motor spinning away.
I remember something about a little piece of plastic that's prone to breaking in there? Does anyone have a fix for that before I tear the door apart?
Thx.
VK
Old 08-16-2002, 12:09 AM
Yeah, it's just that little plastic piece. If you do a search you should be able to find the part number for it. ($10)
The part should have been originally made from aluminum.
Be aware that not the only thing holding up your window is tension and the window will eventually drop after a good bump.
Old 08-16-2002, 07:04 AM
vkykam's Avatar
I guess I'll just have to duct tape it in the meantime.
VK
Old 08-16-2002, 04:18 PM
immortal_suby's Avatar
Thread Killah
You don't need the plastic piece if it only broke at the end. There is some adjustment in the wire's length at the motor and you can tie a knot in the end of it and attach it to the window frame to make it work. If the cable is too short or broke in the middle a brake cable for a bicycle will work ($1.99 @ walmart)
Locker Link
2015 BRZ Limited 6MT
Old 08-19-2002, 11:36 AM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
darn it
If anyone has the part number, it would be much appreciated. Mine just broke and my local dealer thinks it can only be got with an order of the whole regulator assembly. Big bucks! He did say that a part number might exist for it and if so, he can order it.... So, whats the part number?
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 08-19-2002, 12:09 PM
62101PA081 is a sleeve lock regulator. It is a redesign of the clip and is found starting with the 94 SVXs. Scott says it will clip onto the place where the 92-93 window clip used to be.
Evidently there was a problem with this clip and so Subaru decided to offer this as a replaceable part starting in '94. Check out here:
http://www.subaruparts.com/diag/?mod...category=601-1
Cost of the part is $7.58
Old 08-20-2002, 07:54 AM
Chris's Avatar
SVXCESS, you rock! Thanks for the information. I really appreciate it. Part is ordered and be here on Friday. No more vice-grips to hold the window up!
-- Chris
Old 08-21-2002, 04:16 PM
vkykam's Avatar
Price of part from local dealer: $8.84CDN.
Pics are in my locker for the disassembly process.
1) Remove felt from door handle/storage, and remove 3 screws.
2) Remove panel from underneath door opening latch/handle, and remove 2 screws.
3) Remove 2 screws at the "front" of the door, and pry the door panel from the bottom to remove. Panel is held in place by plastic snaps.
4) Remove the trim/armrest support by removing the two screws. Peel back plastic for weather proofing.
5) Adjust the window motor cable using the power window switch until the little "nut-looking" piece on the cable is in this area. Fit the "sleeve lock regulator" onto this "nut". Adjust window manually about 1/2 way down. You will see the black metal support attached to the glass, with a square opening in the middle. Put sleeve lock regulator into opening and slide into place for a snug fit.
6) Reverse removal procedure.
Time: Less than 30 minutes.
Who said this car is expensive to fix?
(I should learn to keep my mouth shut in case my car hears me and breaks something expensive...)
VK
