Old 03-09-2002, 11:46 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Scratches
What do you all do to get rid of the scratches on the windows:
such as the one shown on the picture?
Thanks
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 03-09-2002, 01:15 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
About the only way to remove them is with jewlers rouge and a ton of experience. Take it to your local glass shop that isn't a national chain. They can give you a quote for getting rid of it.
If you try it yourself without the power tools, you'll need an total elbo replacement.
They can also remove the scratches on your front and rear windows from years of wiper scratches.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 03-09-2002, 02:14 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Doug
JC Whitney sells a Cerium Oxide kit, complete with pad that attaches to your power drill. I haven't gotten the nerve to use it, yet. In fact I haven't gotten the nerve to order it yet, but, as bad as my scratches are, I don't think I could screw them up. I was actually in the process of getting a "test window" from eddycat before he left in a huff.
I'd rather have them polished out professionally, but, I'm becoming a real miser in my old age. One thing's for sure: don't even think about having them polished out (yourself, or professionally) until you've replaced the outboard pads that have caused the problem in the first place.
The SVX has both inboard and outboard pads. The outboard pads pick up grit and grime over the years, turning them into sandpaper. That's where the scratches come from. You could try cleaning them, but, I fear that replacement is your best bet to avoid rescratching the surface.
Randy Johnson
Mike Davis -- at Reading VI
Old 03-09-2002, 02:43 PM
Seraph's Avatar
How do I get to them?
Lwin
Current SVX: NONE
Old 03-09-2002, 02:46 PM
Aredubjay's Avatar
Lwin
Sorry to say, you've got to remove the inside door panel, peel back the moisture barrier and, possibly, remove the window glass. You may be able to roll the glass far enough down to pull it back enough to get to the pads, but, my guess is, you'll have to remove the glass.
Randy Johnson
Old 03-09-2002, 02:59 PM
MoreIBNR MoreIBNR is offline
Original Owner 1992-2008
Send a message via AIM to MoreIBNR
I don't think you have to remove the glass. I just had my door panel off last week. If you put the window all the way down, take the panel off, the inside pads are on a bracket that is held on by a single bolt. Remove both the brackets (there are 2 sets of pads - one at the rear of the window and one in the middle). The window will now move enough to give you access to the outer pads which are clipped into the door. You should be able to remove them without removing the glass. (Since I didn't have new ones, I just cleaned all 4 pads with an old toothbrush)
Old 03-09-2002, 06:36 PM
svxeno
And how did they turn out? I'm afraid mine are about to cut thru the window.
Randy (Scratch and sniffle with a tear) ii
Old 03-09-2002, 07:13 PM
svx_commuter's Avatar
I had the PADS out awhile ago. I took the window out on the driver side. Then on the passenger side Like MoreIBNR said if you take off the inside pads or just move them you can clean the outside pads. I used a flat bladed screw driver to fluff up the pads with out taken them out. It worked okay.
My scratches showed up after driving behind a cement truck that was letting dust fly behind it. I guess it got into the window pads. The pads were really flat and stiff before fluffing them up.
I have also been advised by two glass shops not buffing can over heat and break the glass. So now I think the scratches don't look so bad. This would be a junk yard replacement item for me when the time comes.
Old 03-09-2002, 10:01 PM
After brushing with an olg toothbrush, they were fluffed up and all the dust and dirt was gone. How long they will stay fluffed is anybody's guess, but I don't plan on checking on them anytime soon.
As for the minor scratches, that should be the worst thing on my 10 year old car with 140,000 miles! I can live with them.
Old 03-10-2002, 06:00 AM
svxeno
I am looking forward to fluffly window guides!!
Randy (Gettin' ready o FLUFF!) ii
