Old 01-31-2002, 10:32 PM
Replacement Hood Stays or Struts
I need to repalce my hood stays or struts, and I have found them at subaruparts.com. They are close to $ 70.00 each. Are there any suggestions on another place that would be less expensive. I don't want to get them from the bone yard because I would probably be replacing them again in a year or so. Just thought I would check before I bought them online. I'm not cheap - just thrifty - or is it I'm not thrifty - just cheap!
Oh well!!
Like they always say - It's not the principle - it's the money!
Thanks in advance.
Earl
Old 01-31-2002, 11:51 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Replacement Hood Stays or Struts
Oh well!!
Thanks in advance.
Earl
You might PM svxcess. He just replaced his. I don't know what he paid, but, he probably ordered from subaruparts.com also. Unfortunately, I don't believe there are any A/M replacements.
Randy Johnson
Mike Davis -- at Reading VI
Old 02-01-2002, 01:09 PM
calmone
i looked for them for a month or so without success and finally bit the bullet end got them from subaruparts.com. i thought they were reasonable. retail is $96, even used usually expect to pay half that.
Old 02-01-2002, 11:03 PM
stays
I ordered them today from subaruparts.com and they were 67.55 each. I too decided to bite the bullet. I didn't want to mess around with used ones. It will be worth it to be able to lean under the hood and not get the feeling of being eaten by my own car. Thanks for the relpy.
Earl .. ><((*>
Old 02-02-2002, 05:32 PM
svxeno
Re: stays
Earl .. ><((*>
Stopped by Discount Auto Parts here in Florida. Picked up a couple of items called "Shur-Lock"s. Theya re plastic "locks" that have a thumb screw on the side. It stays in the rod and you simmply slide it up when the hood is open and tighten the thumb screw. A $3.99 temporary safety solution.
Randy (Keepin' the hood of'n ma head) ii
Old 02-05-2002, 06:55 PM
htyei's Avatar
htyei htyei is offline
SVX Animated Icon Guy!
Send a message via ICQ to htyei Send a message via AIM to htyei Send a message via Yahoo to htyei
hodo stays
You dont even know how many times I've been almost permanently maimed by my own hood
Henry Yei
htyei@svxwrx.com
1992 Dark Teal LS-L w/o spoiler "OLIVIA"
http://www.svxwrx.com
Old 02-05-2002, 10:03 PM
deadeye95
Just had the experience!!
I got my first "loving head tap" last night as I was cleaning my battery terminal. Hope the cold weather is to blame.....
Old 02-05-2002, 10:48 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Tough call, does one pony up 130 coconuts for new struts, $5 for a small pair of vise-grips (to clamp around dysfunctional strut when open) or rip off wifey's broom and saw off the handle to the correct length? Maybe nab the hood prop rod from a wayward Justy while the owner's head is turned?
Beav
Old 02-05-2002, 10:50 PM
Aredubjay's Avatar
Beav
I'd choose the broomstick. Not only does it make a good hood prop, but, it's readily available to crack the heads of those who might try to touch the car without your permission.
Randy Johnson
Old 02-06-2002, 12:42 AM
I found a broom handle that adjusts in length when turned 1/4 turn that had the broom head broken off. It adjusts from 24" and then expands to a length that holds the hood all of the way up.
I really hate to give someone else my coconuts.
Old 02-06-2002, 01:20 AM
htyei's Avatar
hood drop
anyone ever had the misfortune of leaving something in the engine bya and having it shut automatically? I ahve nice little hols in my sound proofing.
I also have two small holes above my battery terminals(ireplaced them , but I guess they sit slightly higher)
Henry Yei
htyei@svxwrx.com
Old 02-06-2002, 03:24 AM
Beav's Avatar
Not as old as Randy
Re: hood drop
Yup, and I've seen stuff left under the hood make quite a large dent in the hood. I've also seen battery terminals short out by touching the bottom of the hood when it was closed. Makes a heckuva mess and can start a fire. It sounds as though you have the wrong size battery in there Henry.
Beav
Old 02-06-2002, 09:53 AM
Aredubjay's Avatar
I frequently lay tools around the perimeter of the engine bay. I haven't "slipped up" yet, with my SVX. I did, however, drop the hood on my 1980 Mercury Capri RS Turbo once, only to discover that I had left a screwdriver on the inside edge, which bound the latch so tightly, I didn't think I'd ever get it open. I wound up have to pull up on the hood, stick a long scredriver in the space and pounding the other screwdriver out by whacking the handle of the long screwdriver with the palm of my hand. I hate when that happens.
Randy Johnson
Old 02-06-2002, 10:02 AM
htyei's Avatar
battery
Hmm... I havent replaced the battery ever, it's a Diehard, is that the battery that came from the factory or did the previous owner replace it?
The battery size is not the problem though, because I had no trouble before. Of course, if it has been replaced, you maybe right and it is sitting higher, though it seems to fit perfectly.
It happened after I replaced the battery terminals, because the
originals were very loose. Subaru sure doesnt leave a lot of leeway concerning the wiring for the battery. Had a heckuva time
making it fit!
Henry Yei
htyei@svxwrx.com
