Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 06-28-2004, 08:32 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up Newest free mod - Improved throttle response!!!
I was tooling around on my car this weekend and happened to remove my engine cover to clean the outside of the throttle bodies.
While doing so, I was looking at the throttle-by-wire mechanism in our cars, which is attached to a 90* arc mechanism that opens the throttle bodies. There are two wires running in parallel to each other and they are held in place by a metal plate and four screws (two per wire).
I pushed down on each wire and noticed a little slack was in there and decided to adjust the screws so that I could take the 'slack' out of the wires to improve throttle response (did this on my Lightning - popular free mod). Well, I tightened the wire a little too much and when I started my car, the idle was raised to 1000 rpms (with the engine fully warmed).
I then redjusted the screws, and have now set my idle at 700 rpms (100rpms above stock) so that as soon as I step on the gas, there is no delayed response before the throttle bodies open.
I don't have pics as I wasn't planning to do this ahead of time. I'll take some later this week when I get the opportunity and post them.
This is a very easy mod to do and all you'll need is a 12mm wrench (I think - used a standard wrench that was kinda close in size).
-Chike
P.S. On a side note, prior to doing this mod, my 4EAT shifted at 6250 rpms in first, and 6000 rpms in 2nd and 3rd. Now, it shifts at ~6350 rpms in first and 6100 rpms in 2nd and 3rd!
2006 Steel Gray WRX TR (sold)
Old 06-28-2004, 08:43 AM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
This is definitely a good thing to do. Tightening up the throttle cable is one of the first things I do on a new (used) car. if it's too loose, you may never actually hit WOT .
make sure to adjust it when the car is on so you don't make it too tight. one time I did it to the point where it "felt right" with the engine off in my CRX, and my idle ended up at like 1200
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
Old 06-28-2004, 08:53 AM
Chiketkd's Avatar
This is also a good way for the 5MT guys to raise the idle so that their cars don't cut out when idling...
-Chike
Old 06-28-2004, 11:33 AM
Chiketkd's Avatar
Often manufacturers leave a little slack in the throttle line as most drivers don't desire an immediate response when pressing the throttle - can lead to a 'jerkiness' if you like to leave your foot on the skinny pedal when driving!
-Chike
Old 06-28-2004, 12:03 PM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
AWESOME!!, way to go Chike......I'm gonna go do that right NOW!!!.........
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 06-28-2004, 12:44 PM
-Chike
With the 5 speed I wouldn't want the throttle to be any more sensitive than it already is!
I drove a 5 speed Jetta TDI and it's the complete opposite to the SVX. You normally give 1/2 throttle to get moving and let out the clutch at whatever speed you want because it's SOOOOO soft!
With the SVX you press the gas ever-so-slightly and the RPM's make a run for the redline!
Old 06-28-2004, 02:57 PM
Chiketkd's Avatar
You 5MT guys make me mad! This cable adjustment though can help get rid of the stalling that some 5spders get when idling after doing the swap. Mychailo posted a thread about it recently...
-Chike
P.S. After I get a 4.44 tranny and diff put in, you guys will have nothing on my SVX!
Old 06-28-2004, 06:58 PM
Subafreak's Avatar
Superbeast
-Chike
I'll be looking for that time slip.
Old 06-28-2004, 08:32 PM
Chiketkd's Avatar
And you shall get it!
-Chike
Old 06-28-2004, 08:34 PM
Mountaineer
I see a Race brewing........take it to the Pigeon Forge Meeting..........
1992 BMW 325i
Old 06-29-2004, 12:12 AM
MisanthropyV
...the tension thickens
When will you have your 4.444 Chike???
Old 06-29-2004, 07:04 AM
Chiketkd's Avatar
Pics...
Once removing the plastic H-6 engine cover, this is what you'll see on the left hand side of your throtle bodies when facing the engine:
This other pic shows a close up of the two wires and the four screws that need to be adjusted:
-Chike
Old 06-29-2004, 08:14 AM
Chiketkd's Avatar
When the 4EAT in my sig is sold, the '96 Outback trans is going right in! It could be in my my car as soon as 1-2 weeks from now...
-Chike
Old 06-29-2004, 09:24 PM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
Kudos Ol' Chap on the throttle line tightening. I love the way my car responds to the new adjustment. Thanks for the idea.
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 07-01-2004, 02:24 PM
...except for top speed, better cruising RPM and MPG.
