tachometer wiring
help... i bought a dash mount tachometer and need help with the wiring i could figure it out myself but would like to save time... anyone else done one and knows whats up?
Dude, you're on Ft. Benning?? I went out there to get something one time when I was visiting my friend... Cool... You have an SVX right??
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
yeah im at fort benning
i have red svx with black vinyl stripe on sides, exhaust
where did you get your engine grounding kit or did you make it?
heres a picture on my cardomain page http://members.cardomain.com/subaru_newbie
I think u just need, power, ground, illumination and tach signal.
Power -> anywhere - ignition? Ground -> a nice metal screw in the body Illumination -> I think red/black in driver kick, or hit up red/black behind the parking light switch that's attached to the knee bolster panel. Tach Signal -> Hit up the ECU - solid Yellow wire
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
Subaru_Newbie: Why do you want an add-on tach, isn't the one in the dash working - did any SVXs come without a tach (I thought they all had one)? |
the tach works fine i just want one eiasier to see with a nice bright shift light... i will check the yellow wire on ecu... will the voltage jump up when revved up... be easy to find with multimeter... oh and i got a/f gauge... which of the 3 wires from the o2 sensors in sensor signal wire?
ok heres all i need... the tach signal wire , and o2 sensor wire on ecu... oh and where is ecu... under dash on drivers side... sorry stupid question but im new to subaru... btw i have 1995 svx l awd
ok heres what i got... the power ground and illumination are not a problem for me... for either gauge... thats easy its the tach signal wire and o2 sensor signal wire... i downloaded wiring diagrams and got solid yellow wire on 16 pin connector as tach signal, and pin 6 on 22 pin connector solid white is 02 sensor wire... my question is where is the connectors... im assuming under the dash but its dark out and i will have to wait until tomorrow to make sure... any help would be appreciated
Right under the steering column (driver dash) you will see the TCU and ECU ...you can't miss it ....the ECU plugs (4?) are the easy ones in your reach ....those are where u can find ur wires.
did u do a five speed conversion? or you just plan on eating the 4EAT power shifting
eating the 4eat ... i wired up the a/f gauge to the wire i thought it was and all the led light stay on... so i guess i was wrong
