Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Supercharged Projects
  #1291
Old 08-16-2007, 09:14 AM
longassname's Avatar
Just some dude.
To be able to adjust the idle manually you need to disconnect the cold air bypass valve so that whatever you set the idle at is the same warm or cold. When you do this you need to block off the connection on the throttle body and the connection on the intake boot. To adjust the idle just loosen the set screws on the solenoid of the idle air control valve so you can turn the solenoid. That setting determines the base idle. Whatever you set it at the ecu will maintain. With the stage 3 parts it is purposefully mounted where it is easy to get to. With the stock parts it is purposefully mounted whete it is impossible to get to.
Originally Posted by Dessertrunner
Guys I have read comments that you have adjusted the idle up in Rev how have you done it as I am going to look at installing mine soon.
Tony
Old 08-16-2007, 01:57 PM
Dessertrunner's Avatar
Thanks Mike.
Old 09-14-2007, 01:31 AM
SVXDoc SVXDoc is offline
Purchasing a supercharger kit
Sorry to ask a question that I could probably have answered if I read through the 87 pages, but who should I contact about purchasing a stage III supercharger kit?
Eric
Old 09-14-2007, 01:38 AM
LAN aka longassname aka Mike
www.ecutune.com
Old 09-14-2007, 06:03 AM
sicksubie's Avatar
I dont believe you can get them anymore......
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 09-14-2007, 10:28 AM
mikecg's Avatar
mikecg mikecg is offline
I think he may be considering a redesign of the stage III. So you might be able to get one, but it may take some time before it is ready.
Old 09-24-2007, 09:17 PM
jeffast jeffast is offline
I kill more trannies then god
wow when did stage three become unavailble
1991 xt6 eg33?
1993 gc track car
Old 09-24-2007, 10:34 PM
Just some dude.
about the day the first batch was done
Old 09-25-2007, 09:19 PM
as an interisted party, how long till the second batch come along, or will there be a second batch?
1991 xt6 eg33?
1993 gc track car
Old 10-17-2007, 02:57 AM
svxual's Avatar
svxual svxual is offline
is it possible to buy a smaller pulley for the supercharger? and can u get a matching water to air intercooler kit or do i have to custom make one?
Old 10-19-2007, 07:51 PM
sicksubie's Avatar
And you would want a smaller crank pulley because you want to go slower? You cannot run a smaller blower pulley because you would not have enough belt wrap. The crank pulleys that come with the kit are 9psi and 12psi. I am having a larger crank pulley made (15psi).
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-19-2007, 08:00 PM
Speedklix's Avatar
Locker Link Solution
it is almost integral to the manifold, no where to put one
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 03-15-2008, 08:24 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
can we get a 2008 update?
- John
Old 03-17-2008, 10:11 PM
sicksubie's Avatar
No more stage 3 but there is "stuff" in the works....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 04-01-2008, 03:13 AM
May be we could use this type of intercooler.
Tony
