#106
Re: Gearshift Maps
soooo
degrees c = .5882 (atft value) -40 ? |
#107
Re: Gearshift Maps
20c=68f=3 to 3.5v
80c=176f=1 to 1.3v (note 2 volts change = 60c = 1 volt per 30c in normal operating range of sensor, theoretical range then is 0 to 150c) or using the middle of the voltage ranges given for the temps in the fsm: 20c=3.25v -->(3.25/5*255=166=a6) --> (ones complement of a6)5a=90 80c=1.15v -->(1.15/5*255=59=3b) --> (ones complement of 3b)c4=196 (80-20)=m(196-90) m=.566 80=.566(196)+b b=-31 20=.566(90)+b b=-31 y=.566x-b degrees c = .566(atft value) -31 |
#108
Re: Gearshift Maps
I'll eavesdrop on the select monitor to get some values to double check/refine the equation.
for now it's looking like I'll try something like c024:e7 c025:df expecting the warning light to come on at 100c=212f and go off at 95c=203f |
#109
Re: Gearshift Maps
That's why I was thinking Fahrenheit.
C=0.556F-32 Actually, I was surprised that the TCU doesn't use a graph to map sensor voltage to temperature like the ECU does. If it's anything like the ECU, it may not be linear at the top and bottom of the scale. Have you ever tried reverse engineering the Select Monitor itself?
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II Last edited by b3lha; 03-18-2009 at 04:29 AM. |
#110
Re: Gearshift Maps
I just emailed you the bins.
#111
Re: Gearshift Maps
I think celcius = .556 (farenheit-32)
Re: Gearshift Maps
Yeah. You're right. My mistake.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
#113
Re: Gearshift Maps
I've gone with setting
c025 and e201 to df and c024 and e208 to e7 |
#114
Re: Gearshift Maps
looks like the equation from using the middle of the voltage ranges given in the fsm is exactly correct.
I set c024 to 82 and c025 to 65 (110F) --> warning light came on at 111F since the bit is set to turn the warning light on after failing a branch if lower or the same 111f is exactly right. |
#115
Re: Gearshift Maps
Degrees F = value - 20
#116
Re: Gearshift Maps
Thanks. Very Interesting. I already disassembled the 92 bin. Any idea what cpu? The 68HC11 seems to be about 99.9% perfect, but the ROM has a few opcodes in the extension table (0x18 prefix) that aren't in the datasheet. Doesn't matter too much, I have enough good code to follow.
#117
Re: Gearshift Maps
it's a hitachi 630x: hd63b03yp
clocked by a 4000 xtal it uses a toshiba tc74hc125 for the signal from the ecu by the way (clamped before the 125) |
#118
Re: Gearshift Maps
Actually the tx from the ecu is pulled high and clipped not clamped and the rx line is clipped on both sides then they go through the 74hc125 to pins 12 and 13 on the 6303
I made a schematic to duplicate the select monitor interface for an interface to a ftdi ttl232r cable: http://www.ecutune.com/posts/ttl232r-selectmonitor.pdf
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 03-19-2009 at 05:02 PM. Reason: link typo correction |
#119
Re: Gearshift Maps
also, although it is not used I think that wire from the ecu select monitor port that nobody knows what it is is either vcc from the ecu or a comparitor input for the rxd. It is routed straight through the select monitor to pin 35 of the cartridge. In the 92 select monitor cartridge that pin traces to a dead end at a through hole for a resistor. If the resistor was installed it would connect to vcc. I suspect it is vcc from the ecu.
#120
Re: Gearshift Maps
The select monitor rom is a gold mine of information.
As expected, it has the commands for querying ecu, tcu, a/c, cruise and 4ws. Plus a full list of the parameter addresses and trouble codes. I'll document it all when I get a bit further. I've been looking at the routines that validate the TCU romid. It supports THREE types of TCU: 7054xx: ACT4 (USDM). 7055xx: WTF??? 7056xx: VTD (JDM and UK). What could the 7055xx be?
