#106
Tom:
Here it is: HLY-11-4 I'm reading all this about how the switch that is made when the clutch is depressed is supposed to tell the ECU that the phantom 4EAT is in neutral, thus preventing stall, and I'm thinking that my neutral is hard-wired, and it is still stalling.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#107
I know, thats why I feel regaurdless of your wiring, the engine will still stall
Tom |
#108
I'm going to unsubscribe from this one. Good luck guys.
#109
listen, just being practical. Read into it and over engineer a solution all you want but in the long run it comes down to air being there to burn or not. If there is no air to burn, what good is anything else?? Now rmjjenson was onto something with the A/C being on but not running the compressor. I think that the IAC opens further and the fuel is bumped to raise idle. What we need is the same amount of fuel but a little more air. The Dash pot should cure this stalling problem by allowing the idle to settle slowly and keeping enough air in the engine for it to run.
Tom |
#110
I checked tonight, and have my setup wired as lan has described. I have never experienced any stalling. I have a legacy 19lb flywheel. I dont see why we wouldnt all be haviing this problem..it must be something small
phil
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
#111
I've never had a stalling problem with my 5mt. But Mine always idles at around 1000-1100 rpm. Acceleration is sluggish untill it hits 2000rpm then it feels like a turbo kicking in or a shot of nitrous(but I think having no cats is the reason.) I'm also only getting about 17mpg. And my cruise control has never worked since having the manual transmission.
#112
See above ------^
#113
I have occasional stalls since the swap. But I had occasional stalls before as well. I think mine may be related to a dirty manifold, IAC, and throttle plates. I'll let you know after cleaning this weekend.
Agree with Tom about the air issue. Did'nt want to say anything because you guys have been working on the SVX's much longer then me. A simple & cheap way to let more air in is to adjust the throttle cable to open the throttle plates ever so slightly. Opps! apparently this does'nt prove so effective, Quote:
Edit: Top Clutch switch is wired into NSS, so ECU is aware of Neutral when Clutch pressed. 2002 WRX 5mt with stock flywheel. |
#114
has anyone ever tried
It dawned on my a little bit ago and I'm curious:
Has anyone tried wiring the Engine Torque Control signal of the ECU to one of the clutch switches so that the ECU cuts back during shifts? I know it cuts 3 cylinders, or reduces timing, or both....BUT ...if the engine is disconnected from the drivetrain it should still be able to free-rev perfectly fine so you can shift properly at redline ... maybe ..who knows. So has anyone tried this? Maybe when the ECU is in its torque control mode the engine won't stall (more control)? ideas? I might try this but I'd have to wait til next week.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing ![]() 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
#115
Here's what I wrote on the torque control algorithm a few years ago:
------- ... Got home this evening and wired a switch between 5 V and the torque control pin. Driving down the road and toggling between open (unreferenced) and 5 V made absolutely no difference in power. Next, I put the switch between the torque control pin and ground. This is where it got interesting. As long as the throttle position was less than about 75%, there was no difference in engine performance between grounded and ungrounded torque control pin. Above about 75% throttle position, the engine would dog dramatically when the torque control pin was grounded. I think it is indeed pulling back timing. .... -------
#116
i read that and that makes sense for engine performance. ...but what about engine management? That's what we're trying to fix.
I'm talking about maybe the ECU controls the engine differently when the torque control signal goes low (ground). Obviously it does and will harm performance IF the engine is connected through the driveline to the wheels ...won't make power. This is obvious. But, if the engine is disconnected from the driveline (clutch is pressed) maybe the engine wouldn't bog down at high rpms, and maybe the ECU will be controlling the engine (Idle air control valve) differently ONLY if the torque control signal is grounded. So press the clutch in, engine isn't under a heavy load, engine torque control kicks in and smooths the engine RPMS, shift into gear, let off the clutch, engine torque control back to normal. Hey - you never know.
#117
I don't recall the torque control having any effect on idle (less than 75% throttle), but its been a while. If you want to check, its easy enough to test.
#118
That's funny.. that would mean it's an vacuum issue that could be resolved with an in line reducer. The best place for one would be between the air box and manifold.
Which reminds me...when I bought my 92' SVX the air box was cracked from air hose to air hose and the Pressure valve had broken nipples I 'Frankensteined' 10 years ago with shoe goo and epoxy. (Along with cracked vacuum lines) It's high time I check them again...that Pressure Valve I know is beyond shot... ![]() |
#119
![]() Quote:
Has anyone tried installing a resistor/transistor to any of the transmission wires? A resistor just may be enough to give that proper 'balance' the computer needs between engine control and transmission. JMT |
#120
Re: infamous 5MT low idle stall
I believe it's already been proven to be the Idle Air Control Valve (not sure if auxiliary or main) that can't open fast enough when the clutch is pushed in and the rpms start to fall. Someone in this forum removed their IACV but left it connected so as not to throw a code, then installed a non functioning valve in its place that always allowed enough air for idle. Boom. No more stalling.
We should be able to do the same thing, maybe with a cheap plumbing valve from home depot, just to make sure the engine doesn't choke when the throttle closes. I'd love to tinker with this theory myself, but my 5mt swapped SVX just doesn't stall. No idea why but I'll take it ![]()
1992 SVX LS-L : King of the Stable LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors 1993 Legacy sedan : winter beater, supposedly. 1994 Legacy wagon : future drift car? 1995 Impreza coupe : EZ30++, daily racecar. 1997 Legacy GT : date night rocket? 2003 WRX : future winter beater |
