#91
Re: Finally picked up my 96 SVX. Temp gauge moves around a little.
You have incorrectly referred your reply to me, beneath a quoted post by Huskymaniac, while simultaneously using your spade to turn over your turd. ![]() ![]() I have been kind and complied with your request. ![]() N.B. Post #12 reads ---Assuming the leak is exhaust-into-coolant. Is that the most common type of leak for an SVX? ![]() The replies. --- #13: “I do not know what is the most common type of failure for the headgasket. I can say that mine was both oil into coolant and coolant into oil, though.” #14: “If it were causing an overheat, and since he didnt mention huge puddles of coolant underneath his car, id assume it would be..... as its also the most common type of HG leak anyways. Ive only seen about 50 test kits turn yellow on Subarus... which is why I recommended the stuff.” All of these replies are also --- ![]() Replies continue: #15 Another stupid by “kwren”, notably this time negligently devoid of a question mark! --- “ Maybe you pretty much already described it.” Also this by “kwren” #16: --- “It is a basketball team, not the animal. I know that a fluctuating temp gauge is a sign of headgasket issues but I would think the needle would go from normal to warmer not from cooler to normal." Exactly where has there been any association with, or reference to your post reading. --- "The gauge is not going to cause the radiator to lose coolant." ![]() Your outbursts continue to annoy and have now reached a point where the degree of stupidity surely proves senility. You are now definitely rattling your dags/turds. ![]()
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#92
Not every comment is for you. Most responses are for the sane folks! Keith ![]() |
#93
Keith ![]() |
#94
![]() Hooooray Keith. --- Desperate, you have searched diligently from way back and have dragged up substance in the form of post No. #38. “Senility” is surely going back and forward endlessly, in the hope of discovering an opportunity to again become a fool. The problem is that in an effort to remove the substance, sly abbreviation of my the post is proven. Not honest. Not nice. ![]() I have no qualms about being compared with the president of the US. ![]()
#95
Keith ![]() |
#96
#97
Hey, guys, if you are done feuding, can one of you take a crack at my question?
#98
GREAT NEWS GUYS! It looks like the Subaru temperature sender fixed the problem. The gauge went to the middle (just a little below) and stayed there. I even climbed a steep hill and accelerated up it. I am keeping my fingers crossed that the old sender just drifted out of specification. Assuming the gaskets are indeed fine, I am going to try and avoid or push out a future problem. I have switched to Pennzoil high mileage oil and I plan to put some of the Subaru coolant conditioner in the overflow tank so it can work its way into the system. Both should help keep seals and gaskets conditioned and sealed. I also tend not to drive my cars hard so the car has that going for it.
#99
Was your car fully warmed up during your test on the hill? If yes, then things would appear promising for you. Here is to hoping you are the exception and not the rule.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
#100
Yes, it had been idling for quite a long time at the garage and then I took it on "city drive" for about 5 miles. The hill is a short one but very steep.
#101
As is clearly recorded, my intent all along has been to prevent you from jumping to conclusions suggested by several, and therefore rush into spending money needlessly, by immediately assuming head gasket Failure. It is sincerely regretted that my efforts in this regard, have been continually rudely obstructed. Thankfully, throughout you have shown good common sense and understanding and as a result, apparently have not been unduly effected.
#102
I will check back tomorrow for your response... Keith ![]() |
#103
Use a tight fitting radiator funnel, it will contain the rising coolant in the funnel. Use a wrap or two of electrical tape around the funnel to make a tighter seal if necessary. You will end up spilling some when you remove the funnel to put the cap on. Make sure to remove the funnel and put the cap on while it's still running.
I would avoid the Subaru HG juice, just like other HG fixes it could block small passages and disrupt proper flow.
#104
Keith and Trevor, there is a wonderful Private Message feature on this board. You can continue to harass each other privately without subjecting the rest of us to your nonsense...
#105
Please don't, there is no need continue these types of posts. Let it go and move on.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
