Old 09-29-2009, 08:26 PM
SomethingElse's Avatar
word words wording
NO MORE CLICK click CLICK START..ONLY START! starter relay
Well it finally happened to me..click click click yadda yadda yadda why wont this ****ing car start!.....after tracing the wiring diagram and drawing out the circuit I began to do a simple voltage drop test in the most conspicuous area....THE INHIBITOR RELAY!!! GUESS WHAT!!! BAD INTERNAL CONTACTS...VOLTAGE DROP!!!
Ok sorry I got a little CAPS happy
replace relay...start start start start start
US models only, so our non us members with non us spec SVXii could not assist....we suck..before adding relays do yourself a favor and replace the bad one first.
Inhibitor relay + inhibits starting = fail.
Eric
Old 09-29-2009, 08:41 PM
Re: NO MORE CLICK click CLICK START..ONLY START!
How about a little help for the lazy amongst us??
Where abouts?
Pics of the bastard?
Old 09-29-2009, 08:49 PM
word words wording
Mine was hanging under the dash... it may be attached to your steering colum..its a black box relay attached to a harness with 4 pins (connecting to a 5 pin relay as young buck Tom found out the hard way).
wiring diagram calls it starter inturupt relay adapter
I will can take pics tommorrow I need to fix the mess I made...sorry its late
Eric
Old 09-29-2009, 09:15 PM
do show and tell!!
Old 09-29-2009, 09:17 PM
Its the only black relay under the driver's side dash... I will give it a go sometime as my car had serious starting issues before the relay mod. Will be a good test bed to confirm
Old 09-29-2009, 09:21 PM
Sov13t's Avatar
Sov13t Sov13t is offline
Cool find! Relay mod be gun?
Can it start cars that ran out of gas too?
Old 09-29-2009, 09:49 PM
Good one Eric.
Hoooooray, at long long last someone has had the brains to trace the problem.
I have always suspected the inhibit relay because it is a normally closed device. This means that the contacts are closed by only spring pressure and also have limited over travel. As a result they are more prone to give trouble, than normally open contacts.
As I keep pointing out, a fault of this sort left existing, could in future result in a completely open circuit. In which case a slave relay will not overcome the problem. Be very sure it will happen on a wet dark night, a long way from assistance.
Cheers , Trevor.
Old 09-29-2009, 10:27 PM
BoxerFanatic's Avatar
One question:
is it a standardized part, or is it a subaru or SVX specific module.
Part number or specification, as well as location would be helpful. I need to replace my steering column shroud covers anyway...
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 09-30-2009, 04:35 AM
word words wording
Ill do my best to do a quick write up by lunch time, with pics and part #.
And hopfully by this weekend, Ill write up a how-to no start diagnositic flow chart.
Eric
Old 09-30-2009, 05:00 AM
Good one Eric.
The complete start initiate circuit is not on record and this will be of real value. The inhibitor switch, security system and starter interrupt relay are also niggers in the wood pile.
How about breaking open the faulty relay and advising what you find. Return spring pressure weak, obstruction in the armature return, or whatever. You are the first to properly diagnose the fault, so might as well go the full distance.
Cheers, Trevor.
Old 09-30-2009, 05:09 AM
word words wording
Cheers, Trevor.
Already planned to , im pulling it apart as soon as i get to work...i suspect ill find the contacts melted, corroded, and deformed on the secondary half as ive seen before on other bad relays.
Eric
Old 09-30-2009, 06:01 AM
word words wording
got to work..opened it up..sure enough...the spring was slightly deformed causing it to only make contact in one small area...after years of being abused in one spot it began to develope craters
Its just a plain relay the same one used for the band-aid fix 12v 20/30 amps
the #s read 0332204150
the location,
the relay,
and the contacts inside the relay...
Eric
Old 09-30-2009, 07:50 AM
Looks like I know what Ill be doing to the Ebony this weekend!
Old 09-30-2009, 05:31 PM
Attachment 12856
Just as I had predicted.
However I did not expect such a piece of badly designed junk, even though automotive electrics tend to be cheap and crude. My company would not have rated that relay, as capable of switching more than 5 amps of inductive load. It would have been out of the question to use same in any industrial situation.
It is up to the Subaru designers to explain why a diode is not included across the solenoid winding, so as to shunt a nasty inductive opening spike. A normally closed relay opening such an unprotected circuit, is exceptionally vulnerable.
Old 01-10-2010, 10:27 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
the location,
Attachment 12853
Attachment 12854
Adding my two cents. Better pic of location to post in parts location section of How-To.
You will note that it is a long mounting bolt (14mm head) that DOES NOT need to be completely screwed out. The mounting bracket on the relay is slotted and will slip out when the bolt is loosened. IF the part you buy has a mounting hole, simply clip the ends as in pic StarterRelay4.
Bosch part# 0332204150
Autozone part# 19861
Carquest part# RY115
And I fully agree--WHY do the bandaid fix instead of the REAL fix???? Uses the same part.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
20 F150 4X4 King Ranch
FREEDOM IS NOT FREE
