#91
No cold water, its winter here.
#92
Harvey - when I hit it just right - not at full throttle but about 7/8th throttle - I get a noticeably different gear change. Rather than the normal gear change it feels like a shift in a manual where you keep the throttle at max and only change gears with the clutch and gearbox. A slight slipping of the clutch as the gear is engaged and the car jumps forward much harder. In the auto it seems to only happen when my foot is not on the floor, but close to it. The engine revs stay higher on these lucky gear changes.
I like it. But it is extremely difficult to duplicate. Could this be the TCU not performing the torque reduction in the absence of WOT? Will this be what the QC kit will do? If it is, I am in.
#93
tom |
#94
But that is is feeling that it gives. It is very progressive in its operation. If you cruise around town, you won't notice anything different. Use a bit more throttle and the change becomes a bit faster and firmer. Stick your foot into it and the change becomes faster and harder. I have been in Automotive for over 50 years, been on The Network since before it started, I wouldn't dud you Matt. Harvey.
#95
Thanks Harvey,
I sent a note to Budfreak to order a QC.
#96
Care to share a test drive when it's installed?
I can swing by on the BMW. :-)
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
#97
Phil, thanks for the definitive information. You will note that I included the words, “ it would appear that”. Unfortunately I have not been in conference with you and shared your knowledge regarding the software, as has Harvey. On the basis of the information available to me it appeared that a voltage signal was involved, but I also appreciated that test and experiment would be necessary. The manual indicates that either a short circuit, or an open circuit, will record a fault code and this tended to preclude on/off binary control to ground. Fault detection circuitry must be quite sophisticated. In point of fact what you state means that control is easier to achieve than I had anticipated. Regards, Trevor.
#98
Here we have a product offered for sale via a non member, on a conflicting site, without any form of description or specification as to its purpose, performance or use, forthcoming from the manufacturer. This precludes any purchaser from establishing liability in respect of performance or fault.
The scant information available stems from a user apparently supplied with a complimentary sample. Here placebo and vested interest must be taken into account. At this point nothing is certain, it would appear by intent.
#99
Removed by me until Harvey decides his product is complete and is ready to discuss it with the open market.
#100
Harvey,
I understand you have put a lot of work into the QC and I wish you every success with it. Would you mind sharing the technical details of exactly what it does and how it does it? So far we've discussed eliminating the torque control signal, but that could be done by cutting a single wire, so I'm sure the QC must do much more than that. I honestly don't see any reason to keep the design secret because there are very few people here who could figure out how to build one themselves. We are all good mates here and nobody is going to steal the design. Even if somebody did, nobody here would buy a knocked-off copy on principle. So, in terms of how it interacts with the TCU. Which of the TCU input/output signals does it read, which does it modify, in what way, and under what conditions. Phil.
Subaru ECU and TCU Website 1992 Alcyone SVX Version L 1992 Alcyone SVX Version L 1994 Alcyone SVX S40-II 2004 Subaru Legacy 2.5 SE Sports Tourer 1996 Subaru Legacy 2.2 GX Wagon 1988 Subaru Justy J12 SL-II |
#101
#102
1st - thanks to WannaRace for providing the dyno plots of the before and after on one plot
2nd - I still don't understand why the dyno shop can't provide a HP/rpm and TQ/rpm plot. The mph on the x-axis is worthless, IMHO 3rd - Following the conversation up to this point and looking at the dyno plots, it really does just look like what is happening is a almost direct coupling (219 ~95% of 230) during shifts, with perhaps a more efficient coupling between shifts (?). The engine is definitely NOT making more power, we're just seeing a more efficient transfer to the wheels (?). -Bill
#103
#104
As I have been thinking a lot on it, it is because the engine is still spooling power (lack of torque control) between shifts. This spooled up rotating mass is then unloaded onto the t/c when the shift completes and thus the spike... Tom |
#105
I'm happy to be one of the guinea pigs. I'm already planning on a dyno day to test the tomyx intake, so this will be another one to throw in the mix.
