#91
[QUOTE]Actual measurements with the wideband 02 meter of effects on afr due to adjustments to the constant verify that the constant and it's mathmatical properties were correctly identified. With this verfied we can go ahead and make the sofware adjustments for the 740cc injectors and install them.
This by the way is the biggie. Lest it escape anyone's attention, today the last step necessary to unleash major horsepower from the svx was taken. The rest is just engine building, forced injection, the usual stuff the performance industry excells at. So drop the ballons and crank up the music the SVX is now officially in the same league as the skyline....if you build it we can tune it.QUOTE] Now this is exciting!!!!! |
#92
#93
Re: hmmm power
87 Octane is for girly men
![]() ![]() ![]() ![]() -1992 Pearl White Subaru SVX -1995 Briliant Black Mazda Precidia (sold :'( ) -1996 GMC Sonoma ZQ8 pickup http://www.subaru-svx.net/photos/fil...-TL-/20502.jpg -Taras |
#95
![]() ![]() I also heard the difrence between semi large injectors and large ones is not that gig. Ive rode in a 3rd gen Supra with around 740 injectors and it idled like what seemened normal. |
#96
I have no idea what you just said....but WOOHOO!!!!!!! ![]()
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
#97
Eddie '92 SVX LS-L (For Sale! Info and link to pics... ) #9536 blt. 4/92 (late boomer '92) ![]() '01 Audi S4 (2.7L Twin Turbo - 6MT) |
#98
As the fuel pressure rises, as the boost increases, there is not a lot of extra fuel, needed to be added. We have seen No2 set ups adding the same amount of HP, through the std injectors, with added pressure. Cost of the project can be a major factor in its up take, the lower the cost the more you sell. Harvey. ![]()
#99
Today's pictures are of the fuel rails and the installation of the 740cc Nismo injectors into the fuel rails. Our injectors, both the old and new, are what are called side feed injectors. As the name indicates, side feed injectors get their fuel feed from the side. This means they must seal at the top of the fuel rail and the bottome of the fuel rail and have open access in the fuel rail for the fuel to flow to the next injector and into the inlet ports on the side of each injector. You'll notice in the pictures that the new injectors are an exact fit. They are actually made by the same manufacturer that made the factory injectors. The old fuel injectors as pretty much all of the engine management hardware on our cars are labeled JECS. The Nismo fuel injectors are labeled UJ, for unisia jecs (JECS has merged with Unisia). There are differences in the design of the body of the injector between the top and bottom orings; however this does not apear to be any problem. The ports on the old injectors were towards the top side of the openings into the chambers the fuel injectors are held in while the ports on the new injectors are towards the bottom side. I can't speak for certain about why the change on the larger injectors but it seems likely to me that the height of the ports is made closer to the tip in order to reduce "latency." Latency is the measure of the time it takes between first energizing the injector and the actual release of fuel. Although the 740cc Nismo injectors can flow two and a half times the fuel as the old injectors their latencies are very similar. Back to the differences in the body of the injectors. Again, this is just a perception of mine and not known for certain, but it appears that they change the body design along with the port location in order to keep the open space inside of the cyllinders where the injectors are housed the same. I'm guessing they match the volume of the space around the injectors to the volume of the same length of fuel rail between the injectos so that there are no fluctuations in pressure accross the rails.
#100
![]() Last edited by svxsubaru1; 10-06-2004 at 11:34 PM. |
#101
I plugged some numbers into an online injector worksheet. Based on six injectors running max. 75% duty cycle, 0.60 brake specific fuel consumption, and 49psi in the rail. 720cc injectors would support up to about 550 crank hp. Assuming we're losing approximately 35% to the drivetrain that leaves 357 hp to the wheels.
Of course the numbers I used are generic but it sounds pretty close what I would expect. Then again, those are max figures. I wouldn't be surprised if the actual finished kit puts out over 400 crank hp. |
#102
Crazy.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
#103
I installed the fuel rails with the 740cc injectors into our test vehicle thursday and did the preliminary tuning of the software to make it run. Yesterday and today I did the fine tuning and seem to have it down very nicely. Working backwards from the changes I made it appears the factory injectors are someting like 278cc's. Can't say exactly due to fuel pressure differences but they are definitely right around there somewhere. Factory idle was maintained without any problems.
Todays educational lecture: The Nismo 740cc injectors are actually a little bit faster opening than the svx's factory injectors. Their flow rate is 2.65 times that of the factory injectors.These injectors are safely good for 550-600 hp depending on manifold pressure and assuming a bsfc of .6 and a duty of no more than 80%. The fuel pressure remains unaltered except that it will be increased by the same amount of boost. This is much better than running a higher fuel pressure for several reasons. First and most importantly we can accurately adjust fuel delivery with the ecu software. Second the fuel stream is more accurate so that a solid stream will hit the valve and be completely vaporized rather than creating a mist where more fuel is wasted. Third the fuel pump will last infinitely longer and be more dependable at typical oem pressures than at high pressure. These are the reasons oem's use the high 20's to mid 40's pressure range and they hold even truer for performance applications. Summation of the fuel injector choice: These fuel injectors will very accurately deliver fuel for stage III including at high rpms where the time available for fuel injection is short. They also have room to grow so once an engine is built to support higher levels of boost all that will be needed to have stage III put the power out is a smaller pulley.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 10-09-2004 at 08:42 PM. |
#104
what are you a mechanical engenier?
#105
Michael,
Very nice! How does the A/F look at tip in (okay, an old "carb" question ![]() -Bill p.s. how are you going to handle the "software" change to the stage 1 chip to provide the improved timing advance curve?
