#91
Re: TURBOs!?
#92
Re: TURBOs!?
Woah woah woah... let's keep the personal attacks to a minimum.
Just the facts maam. |
#93
Re: TURBOs!?
#94
Re: TURBOs!?
Seriously... bazza, harvey, and bob... if you want to take shots at eachother find another medium. There is good info here i dont want to close this or start pulling posts
Tom |
#95
Re: TURBOs!?
I never claimed to know a lot about tuning. Which is why I plan on using the stage 2 chip until I educate myself on burning Eprom chips specific to my car and modifications.
#96
Re: TURBOs!?
Re: TURBOs!?
So Harvey, your recommendation is to either.
1. Run twin turbos. 2. Run separate pipes to the turbo then merge at the turbo flange. Do I understand you correctly? |
#98
Re: TURBOs!?
Cheers Harvey.
One Arm Bloke. Tell it like it is! 95 Lsi. Bordeaux Pearl, Aust. RHD.149,000Kls Subaru BBS wheels. 97 Liberty GX Auto sedan. 320,000Kls. 04 Liberty 30R Auto Premium. 92.000kls. Last edited by oab_au; 10-13-2012 at 05:53 PM. |
#99
Re: TURBOs!?
This will increase the gas velocity, and help to prevent any expansion that will loose gas temp. Then wrap the whole exhaust in insulating materal. Harvey.
#100
Re: TURBOs!?
#101
Re: TURBOs!?
Now I need to learn how to tune our ECU and burn Eprom chips. Time to go to the electrical section! Last edited by BackWoodsBob; 10-11-2012 at 08:58 PM. |
#102
Re: TURBOs!?
Guys,
This is all very interesting.... mine is a low boost setup running 5 PSI at the moment, no intercooling. Torque curve is the same shape as stock, pulls well upto 5500 rpm and then tapers off. The turbo is a old non-cooled T4/T3 hybrid and driveability is excellent - you wouldn't even know it's blown... performance is effortless rather than explosive and suits the SVX chracteristics well. The engine was turbo charged already in 2000. You with blown EG33s - have you measured your exhaust pressure against boost? I know my turbo is small and am wondering if the expansion side is too restrictive. From my side this is all just general interest at this point - I will go for E85 prior doing anything else, then a water to air IC. There's a ton of info available on the net, though. http://www.hotrod.com/pitstop/hrdp_1...arged_engines/ Check out the table especially. http://www.carcraft.com/techarticles...e/viewall.html Kind regards, Tapani PS Has anyone considered a single twinscroll? Last edited by Tapani; 10-13-2012 at 09:38 AM. |
#103
Re: TURBOs!?
You can see how short the path from one side to the other is. Those articles are good, they talk about the way overlap is not needed on a turboed engine, and the problem with the exhaust pressure, and I agree. Using a twinscroll will solve the interferance, as the two pipes don't join, and can be fitted closer to the manifold, giveing more energy to the turbine. Harvey.
#104
Re: TURBOs!?
Well, mine is of the same type:
http://www.subaru-svx.net/forum/atta...8&d=1332441421 Also, the carcraft article talks about how cam designs vary with the characteristics of the selected turbo (and the complete setup).... If I understood correctly modern setups may run with a very low exhaust/boost pressure ratio - below 1 while mine is probably 2-2,5... with that kind of set up the cam design may approach the NA world and go beyond (increasing the exhaust duration and even tightening the LSA). At some point I will go and talk to the shops and try to find out how my set up would change with a state of the art turbo (at the same location) while maintaining the low boost level and stock engine. Interesting and I think there may be quite a bit potential to extend the torque to the high end of the stock rev range w/o affecting the current sweet area just by swapping the turbo to a more modern one. Any comments? Kind regards, Tapani |
#105
Re: TURBOs!?
Yours is not as short as that one, and running less boost, may not be as affected.
Yes, I am sure that the system can be improved to just increase the torque, across the rev range, that the road car uses. Your got the transmission for it. Harvey.
