#946
Re: SVX Engine cooling "Again & Again"
![]() Harvey.
#947
Did you mean Adam? The figure I posted back on page 56 (?) has both of the aux ports on the pump being returns (one from the LH side of the cross over pipe and one from the heater core). -Bill
#948
Gotcha. So, is the ID for your rad's outlet actually 42mm? Thanks. -Bill
#949
Yes you're right I incorrectly placed/drew the feed line for the heater core to the pump. It comes off the normal position up off the crossover tube. not the pump housing as depicted. The WRX purge tank merely intercepts the heater core circuit and traps any air that may be present in the system. The line coming from the top radiator core(~1/4" ID) is at the highest point in the core as I have the radiator ever so slightly tipped in such a manner as to make it so. Any air in the radiator flows to that point and up the line to the purge tank as well. I have been been beating the ever living balls off this car for awhile and have yet to get it overheating, although our OAT is a bit lower this time of year than in Austrailia. I have a bit of a "back road" circuit that is void of all traffic and pedestrians that I can physically road test my car at speed to put some serious track-like sustained stress on the motor. Last night/early this morning(3am hahaha!) I even went and drove it for about 10 minutes hard non stop around this loop and then came to a complete stop and still didn't overheat. Again though my setup is drastically different than the SVX's ![]() I took the Sti/SVX pump home tonight and am going to start modeling it in CAD for some fluid dynamics testing in the near future here. I may actually test the pump on the junk case setup tomorrow. see what kinda of free time I have in the afternoon. -Adam |
#950
Thanks for posting the figure! I'm a little confused at this point, because I thought the heater core was feed by the port off of the RH side of the crossover pipe, with the return from the heater core dumping back in at the pump. I also thought that the port off of the LH side of the crossover pipe dumped back into the other port on the pump (i.e., both ports on the stock pump are actually returns, not pressurizing anything). Your figure shows nothing tapping off of the crossover pipe. Other than this point, everything in your figure makes perfect sense. :-) -Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 01-25-2010 at 03:33 PM. |
#951
Adam, Bill, Dick, and Harry... meh
![]() Update on my front... I cannot keep the car hot... Granted I am not really leaning into it like I prob should be for a proper test but w/o the stat the temp plumets... I have also reset the fan trigger for around 80*C which means about 176*F... I am installing a 160*F stat in the inline housing when it gets here *not today ![]() Tom |
#952
The last. i.e. # 849, included --- "The Meantime, would you please acknowledge my efforts to assist you with the specific issue you have raised. Refer posts #817, #830, #831, 832 #839." (#849 now included.) If you hate my guts, fair enough, but having me needlessly post and post, increases the complexity of this thread, to the disadvantage of other members. The courtesy of a reply will end the situation.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#953
#954
Not nice Tom,
![]() If you had not done so, you would have been able to observe that I have directly supported you throughout, and have been in agreement with your every approach to the cooling issue. In particular your doubts regarding any benefit in changing the actual radiator outlet and tube. The last time being within #926. Whatever, you have been successful in burying my previous post, this probably being your real intent.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 01-25-2010 at 07:26 PM. |
#955
Yes that was brought to my attention and I corrected myself in the last post I made. The feed for the heater core does in fact come off the crossover tube and then returns back down to the pump suction after exiting the WRX purge tank ![]() I goofed on the epicly-precise MS paint drawing ![]() ![]() |
#956
Tom |
#957
Harvey:
I don't really think I am endangering the engine. I will be taking it sort of easy the first few track days as I get reacquainted with the car. I will be on the look-out for the familiar overheating behavior. I also intend to observe a 6800 rpm redline, for the foreseeable future. I will also be running an Sti radiator cap, and will have both fans running continuously controlled by the Hydra. As I understand it, removing the T'stat from the pump inlet increases the pump inlet to at least 33mm (from 29mm), so there is an improvement there. I've also learned how to purge air from the cooling system, so that problem which caused some of my woes early on will no re-appear. Trevor: I have to say that half the time, I don't understand what you are saying. Separated by a common language and all that. The other half of the time, I think I disagree with you. One thing I am convinced of is that the overheating problem is localized boiling, caused by unbalanced circulation through the block and heads, or by a temporary vapor lock of the pump caused by cavitation at the pump inlet, or by leaking head gaskets. With my new engine, we can rule out the last one. Jack's experience and Tony's experience give contrary evidence concerning the first two causes. Given that Jack is running an electric fuel pump, his problem must be unbalanced flow. Tom's new crossover should solve that problem for me. Tony's problem was obviously caused by cavitation. Moving the T'stat to the radiator inlet should go a long way toward helping that problem. I also want to spend some time with the overflow tank to make sure it doesn't allow air into the system on cooldown. In any event, I have no idea what point of view you are bringing to this discussion. Rather than try to decipher your posts, I mostly ignore them.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#958
Bill Yes
Adam does your flow molding program enable calc's to be done when the liquid is in vacum? Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#959
![]() It's a complicated program, one that I am not as fully adept with as the actual CAD software, but I can get things really close for what it's worth. |
#960
You now indicate that you did not and do not understand my simple question, and the exact topic(thing) involved i.e.:- "Did you confirm that both radiator fans were working at full speed at all times throughout?" I will carefully explain for you, covering both my language and what was included within the preceding/previous text/writings. -- During the time when you were experiencing(having) overheating problems, did you confirm(make sure), that both radiator fans were working at full speed, at all times throughout(when stationery stopped/running slow to cool down/running at high speed)? It was my intention to assist(help), in the event that (if) the automatic controls were not maintaining maximum fan efficiency (not keeping both of the fans going properly and at full speed) thus(and therefore) ensuring(making sure of) maximum (the best possible) air flow after you had ceased(stopped) racing.
