#76
Dan, the clutch release is adjustable. I set it there and since there was full engagement did not move it. If you would like it moved out I can show you how to do it
Tom |
#77
Tom:
Thanks. I'm just getting used to it. It's been 8 years and 2 SVX's (this one is now so different it has to count as a 3rd) since I drove stick as a daily driver. Sheila and I were talking today about my previous cars, and all before the SVX's had been manual. Two VW Beetles, a Chevy El Camino, a BMW 2002tii, a Fiat Spider, an Alfa Romeo Berlina, a Honda Prelude, and a Porsche 911, but 8 years is pretty long. Upshifting is not a problem, nor downshifting into anything but first. They go smoothly without consciously making sure the clutch pedal is on the floor. Maybe I'll make a list of adjustments and some further minor mods, and take a trip down to Beach Haven in a little while and buy some of your time. If you guys work out a dashpot thing, I'll definitely be buying one of those. Mohrds: I bought a complete Sti pedal assembly on eBay, and Tom rebuilt it and used it as a complete replacement for the SVX pedal assembly.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#78
Dan, sounds like a good idea. I never downshifted into 1st in any of my vehicles. I wait until I am stopped to put it into 1st. The synchos are always tight and I feel like I am going to break something when I do it. Thats not the clutch pedal but more the transmission holding it back.
Tom |
#79
The stalling when running to the stop, with a closed throttle, is more a ECU problem. First the ECU has been told that the trans is in N, so it has been trying to control the idle speed, that it should be able to in this condition. But the engine is not free to control. The engine speed is being controlled by the drive train. When running into a corner with a closed throttle, the ECU is trying to slow the idle down. So it winds the Idle Control unit down, but the engine does not respond, so it winds it down further. Then you get to the stop, push the clutch in, all of a sudden now, the engine can responded but, because the Idle Control unit has wound the control right down, the engine stalls. To fix it you may have to try different positions of the ECU N, P, D, shift inputs to cure the problem. Harvey.
#80
#81
#82
Just read that again, thats not what I meant.
What I meant was that the N, P, inputs to the ECU be left open, so the ECU knows that the trans is in gear. The N be switched on, when the clutch is pushed or the box is in Neutral.
This would stop the Ecu from trying to stabilize the idle speed when it is coming to a stop. Harvey.
One Arm Bloke. Tell it like it is! 95 Lsi. Bordeaux Pearl, Aust. RHD.149,000Kls Subaru BBS wheels. 97 Liberty GX Auto sedan. 320,000Kls. 04 Liberty 30R Auto Premium. 92.000kls. Last edited by oab_au; 01-23-2006 at 07:09 PM. |
#83
#84
you don't want the cruise to when the car is in N anyway. This still will not cure the stalling problem though. The neutral switch in Shotgunslade's pedal assembly was not working properly so I had to hardwire it in Neutral all the time so he could start it. It still stalls.
Tom |
#85
Do you have any problems shifting into 2nd gear from a stop?
If so either the return spring in the clutch master is sticking or you can adjust the rod on the clutch pedal. I've had both issues.
#86
the rod needs to be adjusted but it does allow for full release
Tom |
#87
Anatomy of a Stall
Observed this tonite on my drive home from the train station. Approaching a right hand turn, I'm in second gear, braking, about 2000-2200 rpm. Push down the clutch pedal, and turn. The rev's drop like a stone. Suprising how fast. Revs seem to hit zero, all warning lights light up, but then, without letting out the clutch, engine sort of restarts on its own, jumps up to 800 rpm, and settles at 600 or so. What caught my attention was the rate at which the revs dropped.
Contrast that with the next turn. Same thing, except, momentarily, I take my foot off the brake and lightly, very very briefly touch the accelerator, just as I push the clutch down. Rev's rise only as 100 rpm or so, but the rate of rev drop when my foot is completely off the pedal is much slower, and it hits 600 rpm and stays there briefly, until I let out the clutch and give it some gas as I straighten out . Seems like the ECU is actively trying to kill the revs in the first instance, overshoots, and just catches it before it has a chance to die completely. Touching the accelerator in the second instance stopping that from happening. So, I bet, this wouldn't happen if the throttle butterfly didn't immediately close completely when you take your foot off the accelerator. No problems shifting into second while I'm stopped, as long as the clutch pedal is depressed.
#88
Look at it, the way the Ecu does. The Ecu has been told that the trans is in N, so it waits for the 'closed throttle signal', when this arrives, it starts to control the idle speed. It does this by reading the RPM, if it is high it will tell the Idle Air Control to close a bit, it then reads the RPM to see if it is low enough, if not it will repeat the cycle till the RPM is OK. Now look at what is happening. You have closed the throttle and are coming down in speed to stop. The Ecu now has to maintain the idle speed. It should not have to do any thing, as the idle speed was right, last time the throttle was closed. The Ecu reads the RPM, it's like 1700, the Ecu tells the IAC to close down, it keeps looking at the RPM, expecting it to fall. But because the engine is still being driven by the trans, it can't slow down. Eventually you stop. The IAC has been closed right down, you push the clutch in, the engine is no longer driven, it will stall, unless the IAC can act fast enough, to pick the speed up. This condition can be made worse if the IAC is sticky and can't respond fast enough. But the other condition of suddenly closing the throttle to stall, needs the dash pot. I think Huck has the N on the clutch, so the Ecu won't be trying to set the idle speed, till he pushes the clutch in. It may work better if the N was switched by both, the clutch, and the N position on the gear box. Harvey.
#89
You posted while I was writing. Amazing is this what I have been saying. The dash pot will do it on the fast slow down, but a long run down to a corner will still cause the IAC to close down. Bliping the throttle, turns the closed throttle signal off, so it does not have to set idle. Harvey
#90
Just something to kill all of your theories:
I do not have ANYTHING connected to my clutch pedal. Both switches are unplugged. The ECU always thinks it's in Drive by me NOT grounding the P pin or the N pin coming from the Transmission harness. To start the car, the NSS on the transmission harness is jumped with a heavy gauge wire. Starting the car is not controlled by the ECU one bit, the NSS that was in the automatic transmission is what controls when the engine can start. Yes I don't have cruise control - and I don't care. Frankly the SVX cruise control is jerky the way it works - seems more like it doesn't smoothly control the throttle (maybe mine's broken but it's not necessary when I drive anyway). With that said, my car is always in drive, regardless of what gear the 5MT is in or whether the clutch pedal is pushed in or out. I have the 5MT idle stall once in a blue moon. It rarely happens but I can MAKE it happen. Generally when you are turning the wheel and suddenly push the clutch in it sometimes may stall. I believe this to be the power steering pump sucking the little juice that the IAC is feeding into the engine. Want a fix? send +10V to the AC activation wire of the ECU. This will raise the idle to about 750rpms. At the same time, interrupt the output from the ECU that feeds the AC Compressor so it's not always on with a 9V relay. Take the wire coming from the HVAC that used to feed the ECU +10V when the AC Compressor is to kick on and feed it to the relay to activate the compressor when it's really needed and complete the connection you just interrupted. Only draw back is the dam cooling fans ...it can cause both to go on because it thinks the AC is going. I'd have to build a temp sensor circuit to control the fans externally - which wouldn't be hard at all - just lazy. But it works - put your Defroster (or AC) on and unplug the trigger wire at the compressor temporarily - see if you can make the SVX stall
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
