#76
I do not know for certain how you are defining "Fault Mode". You will appreciate that fault indication will occur if the resistor circuit is broken, without there being any integral fault, in which case you could mean a fault indication mode. However the lack of engine braking indicates that you mean an internal system fault of a sort not previously reported, hence the mystery.
#77
So far....I have started the car twice since I replaced my tranny resistor...
The first time cold....No blinking light The second time when the engine was warm....No blinking light.... I'm 2 for 2.......Going to keep monitoring it of course. Jason, you may want to get a new resistor.... |
#78
Wait a min....Jason....have you checked your codes anyways??? 16 blinks means the Tranny is storing a code anyways.... Why don't you disconnect the ground wire like I did in my "Resetting Codes" thread and turn the car to "on" and headlights on... Maybe disconnect and reconnect battery at the same time too.
Just a thought.... Is it possible your problem is not a number 11 tranny code?? Check it...if you haven't done so already. |
#79
What I mean by "fault mode" Trevor is it seems once you unplug the resistor while the vehicle is running(or if the circuit goes to an open), It will not read the resistance if you plug it back in until you restart the car. It would seem the 670 OHMs that smallcar decided on is just enough to keep the computer reading the resistance, But not enough to keep the light from blinking. Here's a test to see if what I think is happening really is:
1.Start the car and let it warm up with the resistor plugged in. 2.Then unplug the resistor and go for a test drive. 3.Drop the shifter into 3rd gear and let off the gas pedal while doing about 45-50 MPH. What do the RPM's do? Do the RPMs drop to nearly idle, Or do they stay up above 2K and supply engine braking?(It should drop to nearly idle and the car will coast as if in neutral) 4.Now pull over and plug the resistor back in without shutting off the engine. 5.Go for another test drive doing the same as before in 3rd gear. Do you get the same results as before? If so, Then I believe the computer goes into a fault mode anytime restance either gets to high or goes infinite(open) and just ignores the resistor circuit until the vehicle is shut off and restarted. This all leads me to believe that what Trevor says is right and we need a lower resistance than 670 OHM. As soon as I get a chance I'll pick up a 400 ohm resistor and see if the light stops blinking. Another things that leads me to believe all this is if I first start the car in the morning, I'll having no blinking power light. For as long as I drive very conservatively and don't activate the shift kit the light will not blink on start up, But the first time I get on it and activate the shift kit the light will blink the next time I shut it off and restart it. But if I shut it off and restart it again, The light does not blink. So the only time it's picking up a fault code and making the light blink is when the shift kit goes to the 670 OHM resistor. |
#81
Damn it....6 for 7.....My seventh startup the light freakin blinked.
Stupid Small Car crappy shift kit!!! Jason, waiting on your results.......... |
#82
Jason, what do you mean "activate" the shift kit?...I drive normally too....
I usually drive in 3 for city and then D on the freeway...and I don't jump on the gas either. |
#83
Don't suppose this was any use.
#84
#86
#87
#88
What a crappy answer, I would expect an answer that has some technical expertize in it, but this is a waste of space. This is the reasoning that I put forward in suggesting a different value resistor: Quote:
#89
I'd love to chime in about circuits, etc. ..but I don't have much knowledge...
The shift kit would have a resistor with the color codes of 1st digit band - Blue, 2nd digit band- Violet, multiplier band- brown ?? to make 670 Ohms correct? So would we all agree to replace that resistor with one in the 400 Ohm range to see if things work? 1st digit band- Yellow, 2nd digit band - black, multiplier band- brown? Correct me if I'm wrong, thanks. |
#90
