Old 09-11-2008, 12:43 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Memory dump of ECU
Originally Posted by TomsSVX View Post
sure there is... but it is in the TCU... I wonder if you can send/recieve from the TCU and ECU at the same time... Phil... do you know the command to read the TCU addresses??
The command to read from the TCU is 45 instead of 78. The address for the trans temp is 0017 and I think the value is in F, with no conversion needed.
If you enter 45001700 in the hex com tool then look at the data that comes back 0017xx. Convert the xx from hex to decimal. Verify that it matches the value from the select monitor at cold, warm, and hot. If not we need to work out the conversion factor.
If you flick back to page 45 in the thread you can see a screenshot of a program I wrote to read info from the TCU. The newest version includes the trans temp and some other stuff.
Is it possible to send command 45 instead of 78 with Evoscan? That would be cool.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 09-11-2008, 08:52 AM
I am not sure of that. Honestly wouldn't know where to look to find out.... Not to mention... I don't have an auto
Old 09-12-2008, 11:49 AM
genzzel genzzel is offline
Will pass gas for $$
Sent note to Hamish to see
Old 09-15-2008, 09:58 AM
b3lha's Avatar
Phil & Belha
Smile Re: Memory dump of ECU
I've just finished giving my website a large overhaul to reflect our latest knowledge. The downside of this is that some of the links and images further back in the thread will no longer work.
http://www.alcyone.org.uk/ssm
Old 09-17-2008, 08:10 AM
b3lha's Avatar
Phil & Belha
This document describes how to build a cable that will allow a Select Monitor and a PC to be connected to the car at the same time. The PC can eavesdrop on the conversation between the SSM and the Car. In this way we can build up a definitive list of the ECU parameters.
Tom has kindly volunteered to give it a go when he gets time.
Phil.
Old 09-17-2008, 08:16 AM
I should be able to get the info for OBDII ECUs as well if it can use the process.
Old 09-17-2008, 08:50 AM
b3lha's Avatar
Phil & Belha
Cool. I wonder if Evoscan works on the OBD2 ECUs.
Even for OBD1, it would be a huge step forward to know that we are using the right parameters for the data logging.
Old 09-17-2008, 09:15 AM
surely. The evoscan cable has two plugs... The OBDII diagnostic plug and the SSMI plug spliced in.
Old 09-17-2008, 03:45 PM
longassname's Avatar
Just some dude.
I believe you only had 2 or 3 parameters wrong when you posted them way back when.
If I may suggest--what you should be working on is identifying the routine that calculates the learned ignition advance correction and where it stores the learned values. This feature of the SVX ECU makes it unecessary to have fancy memory devices which can be rewritten while the vehicle is running in order to do auto tuning. All you have to do is let the ecu do the auto tuning and then pull the learned values to use to correct your ignition advance tables. This is 99.9% of the tuning that is within the abilities of 99.9% of end users.
Old 09-17-2008, 03:57 PM
Phil.
Seems simple enough, firing up the soldering iron now..> Will have the cable ready in a couple minutes
Old 09-17-2008, 04:18 PM
Cable is done... I do not have time to use it tonight, looks like maybe tomorrow afternoon.
Old 09-18-2008, 03:12 AM
b3lha's Avatar
Phil & Belha
Thumbs up Re: Memory dump of ECU
Thanks for the input Michael.
I see what you mean about letting the ECU do the tuning itself. Ingenious. I would never have thought of that. I will spend some time looking in to it.
Old 09-18-2008, 03:16 AM
b3lha's Avatar
Phil & Belha
Nice one Tom. Good luck with the experiment.
Old 09-20-2008, 06:04 PM
http://www.codeplex.com/ssm interesting
Old 09-22-2008, 03:13 AM
b3lha's Avatar
Phil & Belha
Originally Posted by genzzel View Post
Interesting stuff.
I think that might work with the OBD2 SVXes, but probably not the OBD1s.
If somebody started investigating the OBD2 ECU, it would probably open the door to some tuning solutions. The work being done on early OBD2 Impreza ECUs will surely be relevant.
