Old 08-14-2008, 10:54 AM
Re: Memory dump of ECU
Ok I was able to DL the ROM using the new software Phil posted... BUT i have no way of opening it. I also went ahead and dowloaded the Evoscan and purchased their cable considering I cannot use the com1 port for some reason It will only allow me to use their cable?? Has anyone else tried using this program yet??
Old 08-14-2008, 11:49 AM
Ok, trying to use RomRaider to get the dump visible it is giving me error codes saying "content is not allowed in prolog" What steps should I take from here??
Old 08-14-2008, 03:16 PM
Ok i did some searching on RomRaider's forum and dug up Upnorth's old posts. I was able to load his 92 dump and your 92 dump. I am still unable to load the 94 dump from your site or the dump I took off a 94 here today... Says the ROM definition is not found. Any help would be greatly appreciated
Old 08-15-2008, 08:51 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Hi Tom,
Good work!
Please email me the ROM you downloaded and I'll have a look and see why it's not opening. I'll PM you my email address.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-15-2008, 09:04 AM
Thanks Phil, been waiting on a VERY late delivery for the last couple days and figured I would jump on board while I have the spare time... Problem is, now you have really caught my interest, so lets see where this takes us
Old 08-15-2008, 09:20 AM
b3lha's Avatar
Phil & Belha
I had a look at the ROM file.
I've been working with 64K files, so that the addresses match up properly in the disassembly. I wrote the Enginuity/Rom Raider definitions on that basis and I should really fix them to work with the 32K files from the Snowmobile program.
The temporary solution is to preprend 32K of anything to the start of the file, or just copy the file after itself.
In Windows, open CMD.EXE and type
Code:
copy /b HEXDUMP.HEX + HEXDUMP.HEX NEW.HEX
and that should get you a 64K file called NEW.HEX that will open in Rom Raider.
Old 08-15-2008, 09:43 AM
got the returned file to Open in RomRaider no problem... Looks like there are absolutely no differences in graphs when comparing the 92 ECU to the 94 I dumped
Old 08-15-2008, 10:07 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I'm jumping in on this bandwagon too
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 08-15-2008, 05:26 PM
b3lha's Avatar
Phil & Belha
depending upon how things go, I am going to be in the market for a decent writer/eraser. I have a couple stock ROMS around that can be erased so I would rather do some testing with them rather than buying/building adapter boards. Let me know if any of you have one you would like to sell or if you can point me in the direction of some good products...
Let me know if you can't find an affordable writer for the stock chips.
I have two spare adapter boards to sell at cost price. But I need to go back and check my records to see what they cost me.
Old 08-16-2008, 10:31 AM
genzzel genzzel is offline
Will pass gas for $$
Question Re: Memory dump of ECU
Got the EvoScan cable and software. Fired everything up and seems to com well, but addresses(request) seems wrong--rpm not htere, batt shows 20 all the time, speedo is on 20 and coolant is -41C. Can not get much else. Not real sure how to use, but did notice each line is able to be edited. I am guessing i need correct requests--can anyone help me out??? It returns ECU 742522. Here are requests that are there with function:
Batt voltage 1335 x *0.08 volts
veh speed 1336 x *2 kmph
engine speed 1338 x *25 rpm
coolant temp 1337 x -50 degC
ing adv 1053 deg BTDC
airflow 1308 x *5/256 volts
engine load 1305
throttle pos 1329 x*5/256 volts
inj pulse 1306 x*256/1000 ms
ISU duty 1307 x*100/256 %DC
O2 avg 130A x*5000/512 mV
O2 min 0000 x*5000/256 mV
O2 max 0001 x5000/256 mV
knock corr 1054 deg
air/fuel corr 1055 x-128 %
atom press 1340 x*8 mmHg
manifold press 1341 (x-128)/85 bar
Please help----kevin
Old 08-17-2008, 02:11 AM
b3lha's Avatar
Phil & Belha
Use these addresses:
Engine Speed (RPM) 1290
Coolant Temp 1185
Throttle Position Sensor 128C
Mass Airflow Sensor 1283
Engine Load 1282
AF Correction 12AD
Ignition Advance 10A2
Knock Correction 12A7
ISC Duty Cycle 129D
Battery Voltage 12A2
Vehicle Speed 12A4
O2 Sensor (Right) 1291
O2 Max (Right) 12B0
O2 Min (Right) 12B1
O2 Sensor (Left) 1292
O2 Max (Left) 12B2
O2 Min (Left) 12B3
Old 08-17-2008, 06:00 AM
Thank you so much. I sent e-mail to evoscan and he replied that he will also send addresses. I will put these in today. Thank you again!!!!
Old 08-17-2008, 07:33 AM
Put in addresses ----works great!!!!!! Not sure if the calculations are right for temp and speed---I tried to set them for degF and mph instead of degC and kph. LOL think my calc is wrong---what should i use?? Thank you so very much for the help. Also on side note---the O2 left is running bout twice the mV of the right---one bad??? kevin
Old 08-18-2008, 03:41 AM
b3lha's Avatar
Phil & Belha
Cool Re: Memory dump of ECU
Hi Kevin,
If Hamish does send you the addresses, please post there here so we can compare them with my list. That would be a great help with the project.
Phil.
Old 08-18-2008, 04:01 AM
b3lha's Avatar
Phil & Belha
The formula for km/h is N*2. A kilometre is 5/8 of a mile, so for mph it will be N * 2 * (5 / 8) which can be simplifed to N * 1.25
The formula for deg C is N-50. Fahrenheit = C*9/5+32 so the formula is (N-50)*9/5+32 which simplifies to (9N-290)/5
With regard to the O2 sensor, I see three possibilities:
1) The address I gave you could be wrong, double check it against the address that Hamish sends.
2) The O2 sensor could be faulty, switch the two sensors around and see if the problem swaps sides.
3) One side of your engine could be running bad. Someone who knows more about engines than me can advise you on that.
