Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Supercharged Projects
  #751
Old 05-24-2006, 07:17 PM
longassname's Avatar
Just some dude.
Old 05-25-2006, 09:34 AM
Just some dude.
Let's get those 2nd batch orders in. I haven't recieved checks or credit card info yet for either of the 2nd batch systems. We're getting very close to finishing fabrication here and need to get the order for the compressors in soon.
Old 05-25-2006, 09:40 AM
so what is the final price on the 12lb system?
Old 05-25-2006, 10:02 AM
Just some dude.
I'm not charging any more for the "12 lb" system than the "9 lb" or "6 lb" yet. For 1st and 2nd batch I'll give you whichever pulley you want. I suspect with the new belt routing that we will find that the "6 lb" pulley is actually an 8 lb pulley, the "9 lb" pulley is actually an 11 lb pulley, and the "12 lb pulley" is actually a 14 lb pulley. After the 2nd batch I will start selling the larger pulley seperately since it's machined from such a big piece of stock takes so long to make. The price of the system for the 2nd batch is an even $6,500. 2nd batch orderer's also get the opportunity to not have to wait so long to get their systems. Their compressors are getting ordered along with the remaining 1st batch compressors, the supporting hardware is already made, and I have the manifolds on hand to pop them out right along with the 1st batch.
Old 05-25-2006, 11:40 AM
Give me a little while, I need to make some phone calls and see what I can do. I am just tired of guessing and trial and error, I like the idea of the stage 3 and I also have a motor to be built in time. I will let you know, and I will ship that pump out today
Old 05-25-2006, 03:59 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
im sure this question has already been answered but... is it build to my motor or do you send a blot on system?
- John
Old 05-26-2006, 02:40 PM
Just some dude.
It's a bolt on system. Although the tolerences are very tight for the manifold I weld them on a bench engine, as you see in the photographs, to ensure that it will bolt up to an svx engine. I will even be test fitting each system to make sure it's a good matching set before shipping.
Old 05-30-2006, 03:11 AM
Just some dude.
I can't promise I'm going to supply these as part of the kit yet but I've made a 4 piece crank pulley which allows me to change the boost with the change of only the ring which drives the supercharger. The belt doesn't even have to be changed. I haven't drilled and tapped it for assembly yet but otherwise it's complete. Four 6mm socket head bolts will hold it together. With this pulley I've also started recessing the belt grooves .03 inches so that there are flanges on the sides of the belts to make sure they don't walk.
4 pieces with two different size drives for the supercharger belt.
Starting with the alternator drive face down, the smaller choice of supercharger drives stacked onto it.
Then the spindle stacked onto that.
Then the ac drive stacked onto that.
A view of it on it's side
A view of it with the larger supercharger drive selected.
Old 05-30-2006, 05:08 AM
mikecg's Avatar
mikecg mikecg is offline
Small question, what keeps the them from just slipping instead of turning? I didnt notice any kind of key or anything.
Old 05-30-2006, 10:15 AM
Just some dude.
The same bolts that will hold them together. They aren't drilled and tapped yet but they are designed so that the 6mm bolts that will hold them together will go through all 4 pieces.
Old 05-30-2006, 11:21 AM
great idea mike!! I just hope no idiots over torque the bolts and strip them out
Old 05-30-2006, 12:33 PM
mikecg's Avatar
Tom,
You better hurry up and order yours. If some orders dont get made soon Mike may stop producing them. Which means only a hand full of S/C SVXii will ever exist.
Old 05-30-2006, 01:56 PM
I know, need to get my finances in order first
Old 05-30-2006, 03:38 PM
Duckie Duckie is offline
Send a message via AIM to Duckie
not only that, but the longer the second batch wait the longer I am un Supercharged =(.
Old 05-30-2006, 04:47 PM
alltrac alltrac is offline
You must be a pirate.
Victor
