Old 11-22-2012, 08:51 AM
longassname's Avatar
Just some dude.
Re: JDM driveline swap
I've put 300 something miles on the jdm driveline and everything is good so I went back to my US ECU so I can update the firmware without having to socket the JDM ECU. I installed the JDM version of stage1av1 into my US ECU. It's a huge performance improvement over the stock jdm tuning which had some areas of noticeably weak acceleration. There aren't any trouble codes so far. It's looking good so far; I'll drive on it a while and then I'll dig into the TCU.
Old 12-02-2012, 12:50 PM
Just some dude.
I'm up close to 500 miles on the jdm driveline and still no trouble codes or issues. I think it's safe to say now that the jdm firmware can be used in the US ECU with a jdm engine. That means anyone who wants to get a jdm engine doesn't have to find a jdm ECU they just need to get the jdm version of Stage1av1.
Old 12-02-2012, 01:09 PM
92 SVX 92 SVX is offline
If they want the jdm trans though they still need the jdm tcu?
Old 12-02-2012, 03:08 PM
Just some dude.
Yes, that is correct.
Old 12-02-2012, 04:59 PM
What are the differences in the jdm firmware, and the usdm? other then no egr?
I removed my egr on my 92 with no ill effects could I run with jdm firmware?
Old 12-03-2012, 09:11 AM
Just some dude.
I haven't tried to go through cataloging differences between jdm and us firmware. The tuning is different in the stock versions but I use the same tuning in both the JDM and US versions of stage1av1. There may be some benefit to using it in a US car that has the egr removed but I haven't searched it out.
I don't know how the stock JDM tuning performs with Japanese gasoline but it performs poorly with US gasoline. The dreaded hessitation US cars experience with stock firmware is the same or possibly worse with stock JDM firmware. It's very nice to be driving on stage1av1 now. The stage1av1 is a huge improvement over the stock tuning. Acceleration is instantaneous and smooth and you can hear the growl of an engine that has all the ignition timing it wants.
Old 12-03-2012, 09:45 AM
Ok I have one of your chips bought it in Feb 2011 it's that the same then?
Old 12-03-2012, 03:07 PM
Just some dude.
Yes, you would presumably have a stage1av1
Old 01-20-2013, 06:33 PM
Just some dude.
actually it looks like I'm not active enough on nasioc to be granted the priviledge of posting in their for sale forums....either of you want to try to get rid of the 3.45 rear end with the wrx lsd for me?
Old 01-08-2014, 08:34 PM
Just some dude.
As a follow up: I'm still enjoying the jdm driveline. It's a nice set up. I like the 3.7 gear ratio and the vtd. I also like not having egr.
I now have ECUtune firmware in the TCU as well. As I mentioned when covering my going through the transmision, I left the valve body stock in this one so I could use it to work on line pressure maps. I've been doing that.
to summarize:
1)with stock TCUs I like the JDM transmision better than the US. If you have a bad transmission by all means find yourself a JDM TCU and get yourself a JDM transmission.
2)The shift maps in the ECUtune version of JDM firmware really made a nice difference. I had ported the shift maps from the US ECUtune firmware over to the JDM firmware and been told by customers that they were very happy with the results but now I'm driving on them myself. I'm very happy with the results. I don't think you can install the ECUtune version of JDM firmware into a US TCU and haven't tried but it may be possible you can install it into a European TCU. The supply of JDM TCUs seems to be annoying locked up thus far by someone less than sharing; however, there are a good handfull of European SVX owners who may be able to get us EU TCUs.
3)I've made further modifications to line pressure maps which only I and a handfull of people around the globe have been trialing. Things are going well and improvements are very nice. They aren't really specific to the JDM driveline though so I will cover them in more detail elsewhere.
Old 01-08-2014, 10:35 PM
Very nice update, I love manual trans but if I could find jdm trans and tcu I might be tempted to keep it auto, with the rear bias it would be nice.
Old 01-14-2014, 07:45 AM
'E''s Avatar
'E' 'E' is offline
Can you convert a usd box to vtd and if so what part of the vtd box do you need? I'm assuming it's mainly the centre diff.
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 01-23-2014, 08:48 AM
Just some dude.
Here E,
I put pictures when I covered the actual work in the begining of the thread. The mpt, extension housing, and mounts on a US transmission could be replaced with the VTD parts with the transmission still in the car. I don't remember for sure if the harness and speed sensor are different or not. I think they are in which case you would probably have to cut off the us speed sensor and connect up the jdm sensor or get a jdm harness.
So..... into the vtd transmission.
The transmission itself is the same as the US part. All of the differences are in the extension housing. The exception to this is the Japanese seem to put more loving care into the assembly of their own stuff than they do ours. There are paint marks from gear matching and hand assembly checks all over this thing.
Here's a picture of the vtd extension housing.
http://www.ecutune.com/posts/jdm/DSC_9012.JPG
open it up and you find the vtd:
http://www.ecutune.com/posts/jdm/DSC_9015.JPG
pull it out and you have a 4eat just like any us model
http://www.ecutune.com/posts/jdm/DSC_9037.JPG
skipping forward to when i put it back together and we have a vtd again
http://www.ecutune.com/posts/jdm/DSC_9039.JPG
transfer clutch frictions going back in
http://www.ecutune.com/posts/jdm/DSC_9046.JPG
output shaft put on
http://www.ecutune.com/posts/jdm/DSC_9051.JPG
rebuilt jdm transmission closed back
http://www.ecutune.com/posts/jdm/DSC_9060.JPG
Old 01-24-2014, 02:32 PM
'E''s Avatar
'E' 'E' is offline
Ok, I have 7 of these gearboxes lying around
93 black SVX
95 bright red SVX
Old 01-24-2014, 07:17 PM
Just some dude.
What about TCUs?
