Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 11-20-2013, 05:44 PM
Banned
Re: 6 pot mono block Brembo calliper kit
If I were to just have you do up a set in brembo black is price higher or the same? and if I go 6 front 4 rear replacement rotors and pads for the rear are WRX parts correct? but fronts still not sure if there is a us available pad/rotor part number yet until we figure out the part numbers yes?
Old 11-20-2013, 07:25 PM
Tireiron Tireiron is offline
If you go with the STi rear 2 pot (not 4 pot) then the rear will be 05-07 STi pads and rotors which are easy to find.
The front pads have part numbers with different brands including hawk, however they are not carried by most suppliers. Same with the front rotors through DBA and brembo. They both have part numbers which work from the different manufacturing companies. I have yet to contact a US DBA and Hawk dealer to see if they can get the rotors and pads that I am going to use, but I don't see why they shouldn't be able to order them if they are dealers with those companies and they have valid part numbers to order.
As for finding a US vehicle that uses those 6 piston front calipers it is almost impossible. One version of the AMG does, however they are very unavailable. GM and Chrysler both use brembo 6 piston calipers however they use proprietary mounting points, not the universal radial mount. The Nissan GT-R also uses the brembo 6 piston brakes however they use different mounting points also.
I've spent the past 2 weeks researching the US market vehicles that use these, and they very not available here. Even the AMG was limited model years and they swapped to a brembo staggered 8 piston caliper (quite unusual to see staggered pistons instead of in a line).
Thankfully going with the calipers from Ford Australia they are still brembo calipers so if anything ever goes wrong with them the rebuild parts are available for them.
Old 11-21-2013, 06:32 AM
'E''s Avatar
'E' 'E' is offline
Originally Posted by Johnybeas View Post
so just to clarify then it's an oem part that brembo offered through ford as a factory option? I can get with my contact at brembo directly, but I don't want to make an ass out of myself looking for a part number that doesn't exist. The more clarification I can get the better. Thanks!
This is a pic of the sticker with the part number on it, there are no other part numbers cast on the caliper. The oem ford caliper come in red black the black is rare but in the generic brembo calipers I can get black yellow silver and red
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 05-08-2014, 08:02 AM
'E''s Avatar
'E' 'E' is offline
just a little update
i will be getting brackets designed and made up for the US market using the ford mustang shelby cobra GT500 2007-2009 to ease of availability
i can confirm (after buying a set) that mercedes slk55 6 pot callipers are the same as the ford callipers and i believe they are the same part number as the jdm sti brembo 6 pots, if you can find a set then all you need is the brackets i have.
93 black SVX
95 bright red SVX
Old 05-08-2014, 07:36 PM
Very cool info. Great work on this.
Old 05-11-2014, 06:51 AM
'E''s Avatar
'E' 'E' is offline
when i can get a set i will be getting brackets made to suit the other merc/brembo 6/8 pot calipers
93 black SVX
95 bright red SVX
Old 05-11-2014, 09:25 AM
Yea the newer ones use a weird offset 8 piston caliper.
Old 05-11-2014, 12:28 PM
'E''s Avatar
'E' 'E' is offline
Yes they do, I've got a set of lambo 8 pots that I need to make brackets up for as soon as yours are done
93 black SVX
95 bright red SVX
Old 05-28-2014, 05:52 PM
SVXMike1996 SVXMike1996 is offline
Originally Posted by 'E' View Post
Price update
Due too changes to availability of stock (excess ford falcon fpv stock) being sold out, prices have gone up but still cost price
Kit now is $2,760 for just calipers and mounting brackets, price could come down to $660 for brackets plus second hand calipers when and if the become available here.
Does this price include shipping to the U.S.?
Old 05-29-2014, 02:54 AM
'E''s Avatar
'E' 'E' is offline
No shipping is extra
93 black SVX
95 bright red SVX
Old 05-29-2014, 05:32 PM
This is very intriguing!
Ahhh damn, needing 18" wheels is a bit of a breaker. I'd like to stick with 17" for autoX and daily driving. Perhaps I'll rethink this since I have yet to buy anything as of yet. Looking forward to all of the progress.
Old 05-29-2014, 09:59 PM
'E''s Avatar
'E' 'E' is offline
It's only an inch
93 black SVX
95 bright red SVX
Old 05-30-2014, 08:41 PM
It's only an inch
That's what she said....
sorry, back on subject
Old 05-31-2014, 02:59 AM
'E''s Avatar
'E' 'E' is offline
Lmfao
93 black SVX
95 bright red SVX
Old 06-09-2014, 01:25 PM
E, is this the dust shield needed to be installed in the back for the Calipers?
Anything else is needed to make it work on the SVX hub (Hand brake, ABS Sensor, brake lines, etc..)?
