Old 10-27-2009, 11:42 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: unfinished oem rarities list. Help me out you svx crazy people.
Yes - mine also has the IR key / with light around the drivers-side key hole area & the morse-code door handle openers - only took me 10 years to discover all 3 (as I did not have owners manual till 4 year ago).
Mine also has rear deck de-ioniser, blower - it is wired into the fan relay (under glovebox - sort of a t-junction connector).
Old 10-27-2009, 11:56 AM
zavikan zavikan is offline
Thank you so much John. You put a great big dent into this project. I think it is going very well. I learned a couple new things from those posts
A better pic of the deionizer would be GREAT. (we have a small stock shot right now)
I dont know there is anything to take a picture OF for the morse handles (there has to be a better name for this)
James
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 10-27-2009, 04:08 PM
James
http://www.subaru-svx.net/forum/show...0&postcount=41
Old 10-27-2009, 04:17 PM
James
This is from the Australian hand book, on the I/R and Coded handle.
http://www.subaru-svx.net/photos/files/oab_au/37064.jpg
http://www.subaru-svx.net/photos/files/oab_au/37066.jpg
Old 10-27-2009, 09:17 PM
Updated. Thank you.
Old 11-25-2009, 07:48 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
There is no glass sunroof.
If you disagree with the above statement,
post:
pictures
web site
forum discussion
supplier
price
country
part number.
Any two of the above will be fine.
In fact any one of the above would be great!
Not really expecting a positive answer on this.
Dealer installed--not factory.
Pics included--not very good ones (raining), but you can see it pretty well.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
20 F150 4X4 King Ranch
FREEDOM IS NOT FREE
Old 11-25-2009, 11:00 AM
Lee
I would like to try and have a glass sunroof made if possible. (Would of course prefer a part num but i'm probably dreaming.) Could you take some closer pics of the attachments of yours? So I can get one made that attaches like that. Also I think on the normal sunroofs there is a sort of rubber gasket that goes around the sunroof. Is it moved to the outside on the glass one? Thx for the info, my sunroof has some rust and needs to be either replaced or have it cut out filled somehow. I'd rather replace with a glass one
Old 11-25-2009, 11:14 AM
BoxerFanatic's Avatar
lhopp's glass sunroof looks like an aftermarket unit, albeit probably professionally installed. Nothing wrong with that... but it isn't the same as the factory unit, in configuration.
Most of the time when the rubber welt is on the roof side, it is an aftermarket unit. If the roof skin is stamped with a down-turned flange into the steel of the roof, and the seal is on the moving panel, regardless of whether the moving panel is glass or steel itself, those are usually factory installed pieces.
It is hard to stamp and finish the edge of the steel roof skin of the car after the manufacturing process... so the rubber seal goes on the cut edge of the metal roof skin, when the roof is simply cut for the aftermarket unit. Maybe that has changed more recently, but most aftermarket units try to seal to the roof skin that is just cut away.
The previous rumors were of a glass alternate panel, that directly replaces the steel panel in the SVX's factory installed sunroof system. The rumor was that a 90's era Impreza coupe in Australia had a sunroof with a glass panel, the panel being identical dimensions and attachment to the SVX's factory sunroof system, and swapping the glass panel into the SVX's sunroof system works.
We are still looking for confirmation.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 11-25-2009, 02:21 PM
lhopp77's Avatar
You will note that I said it was "dealer" installed and not factory. It was installed by the Subaru dealer when the car was new. It is not as large as the factory metal roof, but it was well done and has never leaked.
I have never claimed there was an OEM glass sunroof and I know there was not. This was a great alternative for people that wanted a sunroof on L and LE models.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
FREEDOM IS NOT FREE
Old 11-25-2009, 02:26 PM
It looks a good job to me Lee.
Also I would suspect the fact that it seals to the rubber gasket externally makes it less susceptible to leaks than the OEM one.
Old 11-25-2009, 08:16 PM
I am thinking I might need a new rubber welt that isn't shrunk or collapsed for mine, as it leaks pretty easily, and the roof leaves a gap at the front or the rear whenever it is closed... and floods the spare tire well...
So I would hope that a fully welted aftermarket unit that seals well would be pretty good.
Old 11-25-2009, 09:03 PM
michael's Avatar
michael michael is offline
What Potholes ???
I was to lazy to read the entire post, did someone mention the CD changer for the trunk? or the blank plate for the trunk mount led. or the BBS's or the shorty center console and 1 piece rear carpet.
Wanted: Steering Wheel
Old 11-30-2009, 09:55 AM
The above sunroof was not that of what I mentioned. I can confirm that I HAVE seen the early impreza panel in person. It went to Reading V. Unfortunately, I did not snap pics....Its on my list of things to get some day!
The short console... forgot about that one! I honestly have NEVER seen pics of that.I would think it would work in USDM cars... (havent looked at my garaged SVX in months to remember)
Also never heard of the blank plate...
CD changer pics would be appreciated. Info and links! Info and links!
(just saw this post get linked to from another thread. glad its useful)
Old 12-04-2009, 02:34 PM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Maybe we could rename this thread?!? "The Official Ultimate Wish List Thread"
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 12-05-2009, 07:44 AM
michael's Avatar
What Potholes ???
http://www.subaru-svx.net/forum/atta...6&d=1260022367
note the short console
