#721
A current description of the kit can be seen on our (our being my company's website; I'm the only person from ECUtune that converses on this forum) http://www.ecutune.com I think to get a good handle on the intake you'll have to go through the whole thread. There machining and fabrication of the seperate sections of the manifold were covered early on in the thread. The assembly of the manifold and the throttle body adaptor were towards the end. The Idle air control manifold and final bypass valve setup are even closer to the end--after mikecg's set up.
Even your brief run down indicates that the project has been tackled in a logical way. I did not realise that commercial interests were involved.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
#723
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#724
allright, I'm back. I got the shop cleaned up and set up more or less the way I want it to start welding manifolds. I got the supercharger pulled out of my car and Jay's manifold prepped and bolted to the bench engine for welding.
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 05-17-2006 at 04:58 PM. |
#725
are those the two halfs of the manifold the OE peices? they look smoother and cleaner
- John ASE certified Master Tech W/ X1 Twin City Fleet repair, St. Paul, MN need work done? Have tools will travel
#726
That's just Jay's way of trying to kill me. He likes to paint his parts so that they give off fumes while I work on them.
#727
Duckie, have you done your exhaust yet? It's time to get working on it. You'll want to have your exhaust and spark plugs changed before you install the stage 3 system. The exhaust really needs to be a lot bigger. Since we're almost doubling the power we need to double the exhaust. You don't have to worry about all the stuff the naturally aspirated guys debate about either. For us it is simple. With the substantial valve overlap we have and manifold pressure anytime the accelerator pedal is pressed we are completely clearing the combustion chamber with a clean air charge; we don't have to worry about maintaining exhaust characteristics to do that. We just need to relieve the restriction.
My choice is new clean 2.25 dual pipes all the way from the exhaust manifolds with a magnaflow x pipe and a pair of dynomax superturbo mufflers. Going to dual 2.25 pipes doubles the flow of the tubing. The xpipe will prevent that annoying resonant sound, quiet the exhaust, and improve flow. The dynomax superturbo mufflers are a three chamber design with fiberglass matting which actually muffle and produce a sound I like while still flowing pretty good at 404 cfm each. If you are going to use cats get a pair of monsters. If they aren't big enough for say a new c6 or z06 vette they aren't big enough for us. |
#728
Ive got the spark plugs ready to go. I was just going to chop off all of my exaust temp. to handle the new power but if you think I actually need to fab something then I will save up.
#729
Michael, this all looks too good to be true!
I have not looked back in the thread to see what you have done in regard to compression ratio. One gimmic is to fit extra gaskets possibly with a solid shim between. Such an arrangement will alter the position of the inlet manifolds. Even if you are not using this method, it might be worth keeping this in mind in respect of possible future adjustments, effecting the position of the heads. I am probably telling you how to suck eggs, in which case do not be offended. You are doing a great job and I am sure the results will be rewarding. Your approach is exactly along the lines I regard as best, for what that is worth
#730
It's not an expensive system if you don't need cats. The mufflers and x pipe all together are $200. I would guesstimate the exhaust shop will charge you $150 to weld it up with 2.25 tubing.
Trevor, there really isn't a need to lower the compression ratio. The shape of our combustion chamber is excellent. This has proved to allow us to run all the boost we want without needing to crack the engine open. I am going to rebuild the engine in my car and will use forged pistons with no dome and deepened, connected valve reliefs which will lower the compression but I'm not doing that because we need to in order to get the power we want. The mating surfaces on my crank and cams are worn so that all my front seals leak. I'm rebuilding the engine to refresh it and am only changing the pistons to support even higher amounts of boost because I'm rebuilding it anyway. I certainly wouldn't drop the compression ratio down into the 8's. I'll be keeping it in the low to mid 9's. I won't be shooting for a compression ratio; I'l be designing the piston to maintain optimum performance of the squish area and shape of the combustion chamber.
#733
See I may or may not need cats depending on if I can get an address in fallon
![]() Last edited by Duckie; 05-18-2006 at 06:43 PM. |
#734
I don't think either of those are acceptable options. Just do the dual exhaust without cats. If you need cats come emissions time put them in then.
Ok sounds good
