#676
The only reason the upper failed, is because it looked like it was rubbing on the P/S line and made a slash in it. Other than that, it was fine.
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#677
http://youtu.be/0RkLXcsbYlk
#678
I bought a set of brand new STi 8x17 wheels today for the SVX. I will get a new set of studded tires for the Outback and put the old ones on these for this winter to play around in the snow with the SVX. Something stickier for next summers track days in the spring.
Tapani |
#679
Niki, not sure if you diagnosed your problem yet, but from the sounds of it it's a bad wheel bearing. Doubt it's tire noise, unless you have very crappy unevenly worn tires...
#680
Re-adjusted the rear wiper. It was sitting too low, fixed the rear wash spray stream angle, which ws also too low. Cleared the front wash nozzles (were clogged with wax). Just when I started feeling good I checked the oil to find it low and making quite a mess around the drivers side rocker cover. Looks like I need to have that gasket replaced again.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#681
repaired power steering, fixed some body wholes and checked the brakes for inspection.
#682
The evidence is that my previous tire on that side was partially destroyed, suggesting that there is a problem external to the hub. I've suspected alignment issues. The roads are such around here that I need it checked every year and I've not done that since last spring. I've just been assuming up to this point that the noise was coming from the CV joint. Now that it has been repaired... the search continues.
#683
Replaced the door speakers. Now I don't have to keep the fade completely to the rear. Can one of the audiophiles out there let me know if I am going to have to get some sort of ring to bridge the gap between the door panels and the speakers.
Also ordered a set of hancook i-cepts for my second (better) set of rims.
'97 SVX 'Brilliant' Reddish '94 SVX Lagina '93 SVX Less Reddish '89 XT6 '08 Impreza '18 Crosstrek Totaled '98 LGT ~180K '97 OBW ~185k '93 SVX Less Reddish Sold '89 XT6 '04 VDC Sedan Parts '89 XT6 '96 SVX |
#684
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#685
Nothing so elaborate, just a small sewing needle.
#686
Vacuumed her out, and scheduled for an inspection tomorrow.
#687
Silver SVX: Removed the driver's side radiator cooling fan assembly. No difference in the temp gauge reading in normal driving (but I wouldn't want to give it a go in summertime traffic).
Had for many months noticed an odd, very intermittent whine from that region. When an idler pulley bearing seized I figured I'd found the culprit. Wrong. Then the other day when I shut off the car after a hard run I felt a faint shudder and heard a slight rumble for just a half-second after the engine had stopped. No-brainer at that point. Guess the motor shaft bearings are shot. Also noted some hairline cracks in the face of the fan, I suppose from 20 years of exposure to all that heat. Already have shiny new goods in hand; $230-something. dcb |
#688
Traded one away for a 95 Cutlass Supreme Convertible.
#689
Was able to turn my CD up loud enough to drown out the exhaust noise.
#690
So it's been abnormally warm here recently.
It snowed heavily, then warmed severely causing interesting ice formations in the road, then that was plowed. So it snowed again yesterday, mostly overnight, then sort of began melting throughout the day on the topmost layer, but stayed frozen underneath. You know those grooves on the side of the road that make a loud buzzing noise and vibrate the car when you drive over it so you wake up as your about to swerve off the road from fatigue, or if you're just not paying attention. EVERY road, every inch of road today was just like that, but WORSE. 60 miles later my ass was numb, but the SVX took it like a champ (the road, not my ass). I expect tomorrow to be at least as bad.
